Ana içeriğe geç
2015 12" Retina MacBook Model A1534 için onarım bilgileri ve kılavuzları
Desktop picture gets distorted
Whenever i touch the track pad of my MacBook13" (A1181) the desktop picture acts weird. It gets distorted and that happens only when i touch it, when i don't, it looks fine. Ive uploaded two states of that distortion. Any idea what it might be?
Resim
Resim
Update (11/15/26)
Ive uploaded here a video of whats exactly happening when im mooving the cursor.
If im not doing anything, there are no lines.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
9 Yorum:
@genik - Yep micro-fractures within the LCD panel so the signals are messed up.
Think off it this way you have a loose light bulb in a ceiling light so it's lit but someone bounces on the floor so the light winks on and off as the connection makes and breaks. That's why you see the flicker. Here you only need to breathe! For it to break.
tarafından Paylaş
Can it be some loose wire that’s not well connected?
tarafından Paylaş
@genik - In a way that's Is the issue!
Within the LCD panel are metal oxide traces which the signals to the discrete Pixel cell turning it on and off. But it's not just that cell it's a column and row of cells. So the traces make and break contact as the panel moves.
So while the light bulb took a bit of a bounce to flicker, here it takes very little as the glass shifts ever so slightly and sometimes the neighboring line shorts across as well.
These lines are about as thin as your hair and are in the middle of the LCD sandwich so you can't fix them and besides that doesn't fix the root cause the rear glass panel has fractured.
tarafından Paylaş
Ok Dan, i get it. Do you think its worth buying and replacing the lcd or shall i just leave it?
tarafından Paylaş
@genik - It all depends on what your needs are as well as finding the part.
This is an older system which finding the part will take some doing! While the part will be somewhere around $200 USD for the full lid assembly used it's not that hard to replace. If you buy the LCD panel alone it's cheaper but there are harder to find and will require much more effort to replace.
Many people like these older systems because of the software they run. If that's not an issue getting a newer system even used might be the smarter direction.
tarafından Paylaş
4 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
This looks more like a LCD screen failure. The display is set up like fabric with a set of Lines that run horizontally as well as vertically. As the upper is present and we see banding in the lower section of the image has lost its horizontal sync.
Other than replacing the display assembly is the only way to fix this. As the display has micro cracks which has severed some of the signal lines.
Update (11/18/26)
With the corrected model now, we have both a part and guide to replace the display
Here's the needed part MacBook 12" Retina (Early 2015-2017) Display Assembly
And here's the guide Retina MacBook 2015 Ekran Düzeneği Değişimi
Is it worth it? Vs getting a Neo system? The cost difference is not that large. Some programs you have now may not run on the Neo. If we judge on repairability I think the Neo wins, both easier and currently parts are going to be around for a lot longer.
Replace a display compatible with the early 2015 to 2017 model A1534 12" Retina MacBook laptop. Includes the 2304 x 1440 pixel 12" LCD screen, aluminum case, 480p Facetime webcam camera. Görseli
Ürün
$584.99
Retina MacBook 2015 Görseli
Kılavuz
Retina MacBook 2015 Teardown
Zorluk:
Orta
Retina MacBook 2015 Ekran Düzeneği Görseli
Kılavuz
Zorluk:
Orta
2 - 3 hours
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
genik sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 99
Her zaman: 99
