Ana içeriğe geç
Uzun yıllardır kullanılan R407 gazlı split klima sistemi
Ac indoor display e1 error
My ac indoor display e1 error what happened is there any operation mistake or what how can repair
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
I asked FixBot your question and its reply is in italics. FixBot AI can make mistakes. Verify critical details from reliable sources.
I [FixBot] couldn't find a specific troubleshooting guide for this exact error in iFixit's knowledge base, but information found elsewhere on the web indicates that an E1 error code on a split air conditioner typically points to one of a few common issues:
  • Temperature Sensor (Thermistor) Failure: The indoor room temperature sensor is disconnected, shorted, or faulty, preventing the control board from reading the ambient temperature.
  • Communication Fault: A loose, corroded, or damaged wiring connection between the indoor and outdoor units.
  • Control Board / Button Glitch: A temporary electronic latch or stuck button on the display panel requiring a system reset.
To troubleshoot, try cutting power to the air conditioner at the circuit breaker for 5 to 10 minutes to allow the control board to fully reset. If the error immediately returns, inspect the indoor unit's wiring connections and temperature sensor near the evaporator coil.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Suryakant Macwan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 13
Son 30 gün: 13
Her zaman: 13
