How to fix stick drift
My character is moving by himself
Bu iyi bir soru mu?
This sounds like a common case of stick drift. Over time sticks start to have some wear and tear from constant use. Consoles/PC have their own ways to adjust the "deadzone" of sticks with software tools. This will fix your issue at least for a temporary time, but is no permanent solution.
First try cleaning around the sticks if you haven't already. Some cotton swabs/q-tips should help a bit. Blow some air in too as it might dislodge any dust or small debris. Stuff like that can screw with the sticks a bit.
If that doesn't solve it then you likely need to do some disassembly and part replacement. Just keep in mind that the stick is usually soldered in and would require proper tools to remove and install new ones.
If you do decide to replace the parts, be sure the replacement parts you order are a correct fit for your controller model. If you need a good kit for disassembly, THIS is a good tool kit and should handle most small screws. You'll also need a soldering kit. THIS is a teardown process of your controller and should help in disassembly if you haven't done it before.
Once you have successfully done the part swap, you may need to realign the new sticks on the software side, but not much else.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 5
Son 7 gün: 16
Son 30 gün: 78
Her zaman: 78
