screen issues ipad air
i have ipad air and i can’t use the touch on my screen. i can unlock using fingerprint but once i get in touch will not work.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Does your iPad have a Home button, and did this start after a drop, liquid exposure, or a screen repair? Touch ID working does not by itself identify what is wrong with the touch screen.
First disconnect any accessories and remove the case or screen protector, then make sure the screen is clean and dry. If touch still does not respond, try a force restart: on an iPad without a Home button, quickly press and release the volume button closest to the top button, then the one farthest from it, and hold the top button until the Apple logo appears. On a model with a Home button, hold Home and the top button together until the Apple logo appears. Apple shows both sequences here: https://support.apple.com/en-us/102642
If touch is still unresponsive after restarting, the next step is a service diagnosis rather than assuming a particular part has failed. Avoid choosing Restore if you have data you need, since that erases the device.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 32
Son 30 gün: 32
Her zaman: 32
@georgesoto56497 Which iPad Air do you have?
Theo Grefalda tarafından Paylaş
