Battery replacement FLIP 4 challenges.
My battery was NOT coming out! I tried prying from the lead wire end, tugging on the wires, etc. What I wound up doing: removed the opposite end cap, took 4 screws out of the USB port assembly to slide it out a little (I could not remove it entirely). This made room to insert a blunt push tool (AKA, an eraser-less drawing pencil's blunt end) in through the end, past the now-moveable USB port, and put that against the bottom of the battery to push it out from the bottom.
It was still not moving. I turned the speaker to the vertical position with the pencil on the workbench, battery lead lead end towed the ceiling. I raised the whole thing up a couple of inches off the bench and rapped it repeatedly so that the penci "tapped" (pretty hard) the battery out of the housing, a bit at a time. I had to persist and be pretty aggressive. It looked like a combination of sticky foam installation tape and swelling got it really stuck.
Also, the end caps (mine had the newer twist-to-release attachment, not the Phillips screws) were really tough to get to turn and there is not much to grab. I used a pair of large channel lock pliers (gently) and was able to get a grip and give them that slight counterclockwise turn to get them off.
Slowly, slowly. All is working well now.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
