Ana içeriğe geç
Sansa Clip+, SanDisk tarafından 2009 yılında piyasaya sürülen bir müzik çalardır.
The screen is blank?
The file is read on my computer perfectly but my screen is flickering a little dimly and I have tried many fixes from gemini and I can see that the screen is blank there is no issue with the screen whatsoever
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
I asked FixBot your question with its reply in italics. Beware of Ai mistakes. I addition to FIxBot's response, another consideration may be battery age since manufacturers rarely if ever state battery life. Some may generalize recharging cycles as 300-500 cycles (or more) before battery degradation, not providing hints of what battery degradation appears in electronics. Users can determine battery wear from usage patterns; more frequent recharging, shorter battery capacity of holding a charge.
"The file is read on my computer perfectly but my screen is flickering a little dimly"
Since your computer reads and writes files to the player without issue, the core storage and USB connection are working properly, but a dim and flickering screen on the Sansa Clip+ typically points to hardware wear or degradation of the OLED display itself 1.
The Sansa Clip+ uses an organic light-emitting diode (OLED) screen, which can lose brightness, flicker, or develop ghost imprints (burn-in) as the organic materials age over time 1.
You can double-check the display settings by navigating to Settings > Display > Brightness in the menu to ensure the brightness level hasn't accidentally been lowered 2. However, if the flickering and dimness persist regardless of settings or firmware updates, it indicates that the display panel is reaching the end of its lifespan 1. Because the device still functions normally as an audio player when connected to a computer, many users continue to operate it blindly or rely on voice/audio cues if using alternative firmware like Rockbox 1.
Device
Sansa Clip Plus
•1guides•8docs
Sources:
1 SanDisk Forums - Screen is extremely dim/basically black
2 Sansa Clip+ User Manual
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
BL4Z3 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 17
Son 7 gün: 17
Son 30 gün: 17
Her zaman: 17
