Ana içeriğe geç
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
Can I replace 802.11b/g card with 802.11n
Is my Imac compatible with the newer 802.11n cards? Thanks.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Yes you can. There is a Sonnet Aria Extreme N PCIe card available which is a straight swap for the Airport Extreme card in your Mac. It will give you N capabilities. But if you have a Core 2 Duo CPU in your machine, you can download an N enabler from Apple which will do the same (for $1.99).
Bu yanıt yardımcı oldu mu?
Puan 4
2 Yorum:
+ do you have a link for that?
tarafından
here
http://store.apple.com/ca/product/D4141Z...
a torrent of it exists on piratebay.org not that i am condoning that type of behavior or anything. ;-p
tarafından
Yorum Ekle
Older equipment cannot operate wirelessly in the 5 GHz band. A firmware, or new card update will not supply the needed hardware.
'''Your only option:
Buy a USB 802.11n adapter' Whatever you buy, be sure that it works with the USB ports (USB 1.1 vs. USB 2.0) and has Mac software'' to support the hardware.
N.
Puan 1
Yorum Ekle
If you have a 2118 iMac it already has a -N adapter installed. What it didn't ship with was a -N driver. From memory there was some issue with Apple issuing a -N machine when they were built so they were advertised as -BG. When the -N drivers were released it was announced that this model and a couple notebooks had -N hardware installed and it was necessary to purchase the -N driver supposedly due to licensing. I bought the driver (under $5) and after installed the router identified the iMac as communicating using -N.
Puan 1
1 Yorum:
very good, I believe Apple charged $1.98 + vote
tarafından
Yorum Ekle
Yanıtını ekle
motherlu sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 2,842
