Ana içeriğe geç
1967-68 Mustang Kick Panel Speaker Replacement
John
John ve 7 diğer katkıda bulunanlar
En son January 3, 2024 tarihinde güncellendi
25 - 40 dakika
Orta
Most people aren't happy when a speaker blows out in their car. Old cars can be intimidating because working on them may be difficult at times. This is the perfect Fast Fix guide for anyone who has that problem with their classic Mustang.
Neye ihtiyacın var
Aletler
  1. 1967-68 Mustang Kick Panel Speaker Replacement, Kick Panel Speaker: adım 1, 2 resimden 1. 1967-68 Mustang Kick Panel Speaker Replacement, Kick Panel Speaker: adım 1, 2 resimden 2.
    • Find the car battery under the hood.
    • On the battery locate the black negative battery terminal.
    • Next unscrew the knob on the disconnect.
    • Lastly move the negative lead away from the batter terminal.
    • Make sure not to cross the battery leads.
  2. 1967-68 Mustang Kick Panel Speaker Replacement: adım 2, 1 resimden 1.
    • Locate the kick panel speaker that needs to be replaced.
  3. 1967-68 Mustang Kick Panel Speaker Replacement: adım 3, 1 resimden 1.
    • Locate the two top screws as well as the two bottom screws for the speaker.
    • Check the kind of screws that were used to hold the speaker in place.
  4. 1967-68 Mustang Kick Panel Speaker Replacement: adım 4, 3 resimden 1. 1967-68 Mustang Kick Panel Speaker Replacement: adım 4, 3 resimden 2. 1967-68 Mustang Kick Panel Speaker Replacement: adım 4, 3 resimden 3.
    • You are now ready to start replacing the speaker.
    • A philips head screwdriver will be needed.
    • Do not use a socket in this situation because it may mess up the speaker guard.
    • Lastly make sure to remove the screw completely without stripping out the screw hole.
  5. 1967-68 Mustang Kick Panel Speaker Replacement: adım 5, 3 resimden 1. 1967-68 Mustang Kick Panel Speaker Replacement: adım 5, 3 resimden 2. 1967-68 Mustang Kick Panel Speaker Replacement: adım 5, 3 resimden 3.
    • The speaker guard and speaker are now ready to be removed.
    • Be careful when removing the speaker. Do not pull the wires tight.
  6. 1967-68 Mustang Kick Panel Speaker Replacement: adım 6, 2 resimden 1. 1967-68 Mustang Kick Panel Speaker Replacement: adım 6, 2 resimden 2.
    • Locate the wires on the back of the broken speaker.
    • Remove both the positive and negative wires.
  7. 1967-68 Mustang Kick Panel Speaker Replacement: adım 7, 2 resimden 1. 1967-68 Mustang Kick Panel Speaker Replacement: adım 7, 2 resimden 2.
    • Now locate the new speaker.
    • Slide the positive and negative wires onto the speaker terminals.
  8. 1967-68 Mustang Kick Panel Speaker Replacement: adım 8, 3 resimden 1. 1967-68 Mustang Kick Panel Speaker Replacement: adım 8, 3 resimden 2. 1967-68 Mustang Kick Panel Speaker Replacement: adım 8, 3 resimden 3.
    • Place the speaker back into the kick panel housing.
    • Line up the speaker holes with the existing holes in the kick panel.
    • Be careful not to pinch the speaker wires.
    • This would be a good time to replace the speaker wires if needed
  9. 1967-68 Mustang Kick Panel Speaker Replacement: adım 9, 2 resimden 1. 1967-68 Mustang Kick Panel Speaker Replacement: adım 9, 2 resimden 2.
    • Place the speaker guard back over the speaker.
    • Screw in all four screws
    • Do not over tighten the screws or the holes will strip out.
  10. 1967-68 Mustang Kick Panel Speaker Replacement: adım 10, 2 resimden 1. 1967-68 Mustang Kick Panel Speaker Replacement: adım 10, 2 resimden 2.
    • Reconnect the negative battery terminal.
    • Screw the knob until it is snug.
Sonuç
You have now replaced the speaker.
Bir başkası bu kılavuzu tamamladı.
John
101 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 15-7, Green Fall 2015 Cal Poly, Team 15-7, Green Fall 2015 üyesi
CPSU-GREEN-F15S15G7
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 38
Her zaman: 1,872
