Ana içeriğe geç
1978 Datsun 280Z Turn Signal Flasher Replacement
Lola Yates
Lola Yates ve 2 diğer katkıda bulunanlar
En son June 20, 2024 tarihinde güncellendi
30 dakika
Orta
Öne Çıkan Öğrenci Kılavuzu
A fully functional set of turn signals is not only required by law, but vital for good communication and overall road safety. If one or more of your turn signals have stopped working or are not functioning properly, you may have a bad flasher unit.
In this tutorial, we will demonstrate how to replace the flasher unit on a 1978 Datsun 280Z.
Warning: This procedure includes tasks that can cause severe damage to your equipment and health if you fail to follow the precautions outlined within this procedure.
  1. 1978 Datsun 280Z Turn Signal Flasher Replacement, Turn Signal Flasher: adım 1, 3 resimden 1. 1978 Datsun 280Z Turn Signal Flasher Replacement, Turn Signal Flasher: adım 1, 3 resimden 2. 1978 Datsun 280Z Turn Signal Flasher Replacement, Turn Signal Flasher: adım 1, 3 resimden 3.
    • Locate the hood latch on the bottom left side of the steering wheel.
    • Pull the latch to release the hood.
  2. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 2, 3 resimden 1. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 2, 3 resimden 2. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 2, 3 resimden 3.
    • Unclip and lift the hood.
  3. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 3, 3 resimden 1. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 3, 3 resimden 2. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 3, 3 resimden 3.
    • Lift the inspection cover on the left side to uncover the battery.
  4. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 4, 3 resimden 1. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 4, 3 resimden 2. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 4, 3 resimden 3.
    • Attach a 13mm socket to a ratchet extension then attach the extension to a drive ratchet.
    • Loosen the 13mm bolt from the negative terminal of the battery.
    • You do not need to remove the nut from the terminal bolt completely. The terminal should slide off the post once the nut is loose.
    • Be sure to keep your ratchet or any other metal items from touching both the positive and negative terminals while performing this task. Connecting metal to both terminals creates a new path of electricity and could cause serious chemical, electrical, and flammable damage to your equipment and/or health.
  5. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 5, 3 resimden 1. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 5, 3 resimden 2. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 5, 3 resimden 3.
    • Remove the negative battery cable from the post and set it far enough aside so that it cannot come in contact with the negative battery post while you are working.
    • If the negative terminal comes in contact with the negative battery post while you are performing electrical work, the vehicle will become energized and you risk damaging your equipment and shocking yourself.
    • Wait 10 minutes for electricity to bleed out of the system to ensure safety in the proceeding steps.
  6. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 6, 1 resimden 1.
    • The flasher is located under the dash on the right side of the steering wheel column.
  7. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 7, 1 resimden 1.
    • Disconnect the cable from the flasher.
    • It is a good idea to inspect the wires for corrosion, heat marks, open wires and other defects. Any of these defects could be a reason your flasher became faulty in the first place and possibly lead to another faulty flasher in the future if not addressed.
  8. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 8, 2 resimden 1. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 8, 2 resimden 2.
    • Attach a 10mm socket to an extension then attach the extension to a drive ratchet.
    • Unbolt and dismount the flasher.
  9. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 9, 3 resimden 1. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 9, 3 resimden 2. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 9, 3 resimden 3.
    • The aftermarket flasher replacement doesn’t come with a fixed mounting L-bracket, so it’s necessary to create a safe and functional alternative.
  10. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 10, 3 resimden 1. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 10, 3 resimden 2. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 10, 3 resimden 3.
    • Place new the flasher parallel to the new L-bracket.
    • Slide in the L-bracket in between the new flasher and the hose clamp.
  11. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 11, 1 resimden 1.
    • Tie the L-bracket to the flasher with the hose clamp once they are aligned.
    • Do not over tighten, as there are fragile plastic parts inside the new flasher that can break.
  12. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 12, 1 resimden 1.
    • Bolt in the new flasher using the same 10mm socket and drive ratchet assembly you created from step 8.
  13. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 13, 3 resimden 1. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 13, 3 resimden 2. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 13, 3 resimden 3.
    • Connect the cable.
  14. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 14, 3 resimden 1. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 14, 3 resimden 2. 1978 Datsun 280Z Turn Signal Flasher Replacement: adım 14, 3 resimden 3.
    • Reconnect the negative battery terminal by reversing the order of tasks outlined in step 5.
    • Be sure to fasten the cable to the post tight enough so that it can not slip off the terminal post under any circumstances.
    • Power up your vehicle and test your turn signals.
Sonuç
Close the hood and you’re done!
Bir başkası bu kılavuzu tamamladı.
Lola Yates
241 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 31
Her zaman: 398
