Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This guide will show you how to remove and replace the front brake rotors on the '86-'93 Volvo 240.
Whenever working on brakes, it is a good idea to keep one side assembled to use as a reference. Never drive a car that has only had its brakes on one side changed, as this will cause the car to pull to one side when braking.
Neye ihtiyacın var
Jack up the front of the car and place it on jack stands.
Use an impact wrench or lug wrench to remove the five 19 mm lug nuts from the front wheel.
Pull the front wheel off the wheel lugs and set it aside.
Use a 15 mm box end wrench to remove the two bolts on the back of the brake caliper.
To reassemble your device, follow these instructions in reverse order starting at Step 3.
3 farklı kişi bu kılavuzu tamamladı.
