2001-2005 Honda Civic Headlight Bulb Replacement
Giriş
1. adıma gitIf your headlight goes out on your 2001-2005 Honda Civic, use this guide to replace it. Fixing your headlight is relatively easy and a short process. It is important to be careful during this replacement because the new headlight bulb can be easily damaged. Before starting this guide, make sure your car is not running.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
Unlock your hood by pulling on the hood release located by the front of the driver side door.
Find the release near the center of the hood and push up on it to pull up the hood.
Prop the hood up in place. The end of the prop is found near the battery and it lays across the front of the hood.
4 farklı kişi bu kılavuzu tamamladı.
