Ana içeriğe geç
2002 Toyota Tacoma Headlight Bulb Replacement
Neye ihtiyacın var
  1. 2002 Toyota Tacoma Headlight Bulb Replacement, Headlight Bulb: adım 1, 1 resimden 1.
    • Pull the lever under the steering wheel.
  2. 2002 Toyota Tacoma Headlight Bulb Replacement: adım 2, 2 resimden 1. 2002 Toyota Tacoma Headlight Bulb Replacement: adım 2, 2 resimden 2.
    • Pull up on the lever under the hood.
    • At the same time, lift the hood of the car.
  3. 2002 Toyota Tacoma Headlight Bulb Replacement: adım 3, 2 resimden 1. 2002 Toyota Tacoma Headlight Bulb Replacement: adım 3, 2 resimden 2.
    • Remove the metal rod.
    • Insert the metal rod to hold the hood in place.
  4. 2002 Toyota Tacoma Headlight Bulb Replacement: adım 4, 2 resimden 1. 2002 Toyota Tacoma Headlight Bulb Replacement: adım 4, 2 resimden 2.
    • Pinch the rubber cover and disconnect the headlight bulb.
  5. 2002 Toyota Tacoma Headlight Bulb Replacement: adım 5, 1 resimden 1.
    • Push down on the metal lever to release it. After you have released the lever you can remove the bulb.
  6. 2002 Toyota Tacoma Headlight Bulb Replacement: adım 6, 1 resimden 1.
    • Remove the headlight bulb cover when you are ready to install it.
    • Do not touch the bulb or let it touch anything to prevent it from getting damaged.
Sonuç
To reassemble your device, follow steps 3-5 in reverse order. At the end of step 3 make sure to push down on the hood to lock it back into place.
Bir başkası bu kılavuzu tamamladı.
Drake Fenwick
133 İtibar
1 Kılavuz yazıldı
Bir Yorum
thank you, saved me alot of time.
harley cortez - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 1,635
