Ana içeriğe geç
2002 Toyota Tacoma Headlight Bulb Replacement
Drake Fenwick
Drake Fenwick ve başka bir katkıda bulunan
En son June 8, 2021 tarihinde güncellendi
15 - 20 dakika
Kolay
Daha iyi giriş
It is very easy to remove and replace your headlights in your 2002 Toyota Tacoma. You can save a lot of time by replacing the bulb yourself. The replacement is a H4 9003 bulb. The process is easy and requires no tools to get the job done.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. 2002 Toyota Tacoma Headlight Bulb Replacement, Headlight Bulb: adım 1, 1 resimden 1.
    • Pull the lever under the steering wheel.
  2. 2002 Toyota Tacoma Headlight Bulb Replacement: adım 2, 2 resimden 1. 2002 Toyota Tacoma Headlight Bulb Replacement: adım 2, 2 resimden 2.
    • Pull up on the lever under the hood.
    • At the same time, lift the hood of the car.
  3. 2002 Toyota Tacoma Headlight Bulb Replacement: adım 3, 2 resimden 1. 2002 Toyota Tacoma Headlight Bulb Replacement: adım 3, 2 resimden 2.
    • Remove the metal rod.
    • Insert the metal rod to hold the hood in place.
  4. 2002 Toyota Tacoma Headlight Bulb Replacement: adım 4, 2 resimden 1. 2002 Toyota Tacoma Headlight Bulb Replacement: adım 4, 2 resimden 2.
    • Pinch the rubber cover and disconnect the headlight bulb.
  5. 2002 Toyota Tacoma Headlight Bulb Replacement: adım 5, 1 resimden 1.
    • Push down on the metal lever to release it. After you have released the lever you can remove the bulb.
  6. 2002 Toyota Tacoma Headlight Bulb Replacement: adım 6, 1 resimden 1.
    • Remove the headlight bulb cover when you are ready to install it.
    • Do not touch the bulb or let it touch anything to prevent it from getting damaged.
Sonuç
To reassemble your device, follow steps 3-5 in reverse order. At the end of step 3 make sure to push down on the hood to lock it back into place.
Bir başkası bu kılavuzu tamamladı.
Drake Fenwick
133 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
thank you, saved me alot of time.
harley cortez - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 1,639
