Ana içeriğe geç
2007 Honda Accord Bass Speakers Replacement
Frankie
Frankie ve 6 diğer katkıda bulunanlar
En son June 14, 2024 tarihinde güncellendi
3 - 5 saat
Zor
Daha İyi Resimler Gerekli
Daha Fazla Görsel Gerekli
This guide is for replacing the bass speakers in a 2007 Honda Accord. While driving your Honda Accord you may notice that the speakers are not working up to your standards. No need to worry. Replacing them yourself instead of taking your car to a shop is safe, easy, and affordable. So follow the following steps and you will have a new bass speaker in your Honda Accord in no time.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. 2007 Honda Accord Bass Speakers Replacement, Bass Speakers: adım 1, 3 resimden 1. 2007 Honda Accord Bass Speakers Replacement, Bass Speakers: adım 1, 3 resimden 2. 2007 Honda Accord Bass Speakers Replacement, Bass Speakers: adım 1, 3 resimden 3.
    • Use the plastic opening tools to remove the floor trim panel on the driver's side door.
  2. 2007 Honda Accord Bass Speakers Replacement: adım 2, 3 resimden 1. 2007 Honda Accord Bass Speakers Replacement: adım 2, 3 resimden 2. 2007 Honda Accord Bass Speakers Replacement: adım 2, 3 resimden 3.
    • Remove the shifter frame panel with the same opening tools.
  3. 2007 Honda Accord Bass Speakers Replacement: adım 3, 3 resimden 1. 2007 Honda Accord Bass Speakers Replacement: adım 3, 3 resimden 2. 2007 Honda Accord Bass Speakers Replacement: adım 3, 3 resimden 3.
    • Unclip the heated seats harnesses.
    • Remove the 12V power supply connection.
  4. 2007 Honda Accord Bass Speakers Replacement: adım 4, 3 resimden 1. 2007 Honda Accord Bass Speakers Replacement: adım 4, 3 resimden 2. 2007 Honda Accord Bass Speakers Replacement: adım 4, 3 resimden 3.
    • Remove the cubby space to access the head unit.
  5. 2007 Honda Accord Bass Speakers Replacement: adım 5, 2 resimden 1. 2007 Honda Accord Bass Speakers Replacement: adım 5, 2 resimden 2.
    • Remove the center climate vents with the opening tools.
  6. 2007 Honda Accord Bass Speakers Replacement: adım 6, 3 resimden 1. 2007 Honda Accord Bass Speakers Replacement: adım 6, 3 resimden 2. 2007 Honda Accord Bass Speakers Replacement: adım 6, 3 resimden 3.
    • Remove the head unit from the dash.
  7. 2007 Honda Accord Bass Speakers Replacement: adım 7, 3 resimden 1. 2007 Honda Accord Bass Speakers Replacement: adım 7, 3 resimden 2. 2007 Honda Accord Bass Speakers Replacement: adım 7, 3 resimden 3.
    • Attach the wiring harness into the amp by clipping it in.
  8. 2007 Honda Accord Bass Speakers Replacement: adım 8, 3 resimden 1. 2007 Honda Accord Bass Speakers Replacement: adım 8, 3 resimden 2. 2007 Honda Accord Bass Speakers Replacement: adım 8, 3 resimden 3.
    • Run the wires under the back seat and along the driver's side door sill (removed in step 1) to under the steering wheel.
  9. 2007 Honda Accord Bass Speakers Replacement: adım 9, 3 resimden 1. 2007 Honda Accord Bass Speakers Replacement: adım 9, 3 resimden 2. 2007 Honda Accord Bass Speakers Replacement: adım 9, 3 resimden 3.
    • Drill a hole through the firewall located on the foot well of the driver's side under the steering wheel.
  10. 2007 Honda Accord Bass Speakers Replacement: adım 10, 3 resimden 1. 2007 Honda Accord Bass Speakers Replacement: adım 10, 3 resimden 2. 2007 Honda Accord Bass Speakers Replacement: adım 10, 3 resimden 3.
    • Run the power and ground wires from the trunk through the door sill and through the firewall to the engine bay.
  11. 2007 Honda Accord Bass Speakers Replacement: adım 11, 3 resimden 1. 2007 Honda Accord Bass Speakers Replacement: adım 11, 3 resimden 2. 2007 Honda Accord Bass Speakers Replacement: adım 11, 3 resimden 3.
    • Run the power wire where it will be out of the way.
    • Run the power wire (red) and the ground wire (green) to battery, connect red to positive and green ground to a clean piece of the car body.
    • Make sure to leave the power wire off until finished.
  12. 2007 Honda Accord Bass Speakers Replacement: adım 12, 3 resimden 1. 2007 Honda Accord Bass Speakers Replacement: adım 12, 3 resimden 2. 2007 Honda Accord Bass Speakers Replacement: adım 12, 3 resimden 3.
    • Remove the wiring harness from the back of the head unit.
    • Connect the four speaker wires and one remote wire to the harness as suggested in the owner's manual.
  13. 2007 Honda Accord Bass Speakers Replacement: adım 13, 3 resimden 1. 2007 Honda Accord Bass Speakers Replacement: adım 13, 3 resimden 2. 2007 Honda Accord Bass Speakers Replacement: adım 13, 3 resimden 3.
    • Clamp down the wire harness on the five wires.
    • Tape up the wire loom to keep it neat.
    • Insert the wire harness back into the head unit.
  14. 2007 Honda Accord Bass Speakers Replacement: adım 14, 3 resimden 1. 2007 Honda Accord Bass Speakers Replacement: adım 14, 3 resimden 2. 2007 Honda Accord Bass Speakers Replacement: adım 14, 3 resimden 3.
    • Put the head unit and the panels back into the car.
Sonuç
To reassemble your device, follow the instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Frankie
253 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 28
Son 30 gün: 60
Her zaman: 3,109
