Ana içeriğe geç
2014 Ford F150 Lariat Airbag Clockspring Replacement
Cindy Everitt
Cindy Everitt ve başka bir katkıda bulunan
En son January 15, 2025 tarihinde güncellendi
45 dakika
Orta
Öne Çıkan Öğrenci Kılavuzu
The clockspring is a plastic circuit in a vehicle's steering mechanism that connects the steering column to the steering wheel without breaking the electrical connection when it rotates.
When the clockspring fails, the steering wheel loses its electrical connection, and its buttons, horn, and other features stop working. This guide will help you replace the clockspring and restore the functionality of the steering wheel buttons in a 2014 Ford F150 Lariat pickup truck.
Before beginning this procedure, place your vehicle in park, engage the parking brake, and power off the ignition.
  1. 2014 Ford F150 Lariat Airbag Clockspring Replacement, Airbag Clockspring: adım 1, 2 resimden 1. 2014 Ford F150 Lariat Airbag Clockspring Replacement, Airbag Clockspring: adım 1, 2 resimden 2.
    • Disconnect the cables to your vehicle battery using a socket wrench and 10mm socket.
    • Wait 10-15 minutes for the capacitors to discharge to ensure that no power can trigger the airbag to deploy.
  2. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 2, 2 resimden 1. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 2, 2 resimden 2.
    • Make sure that your steering wheel and wheels are in the straight position.
  3. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 3, 2 resimden 1. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 3, 2 resimden 2.
    • Find the two holes on the sides of the steering wheel.
    • Insert a small screwdriver into the hole on one side and push to release the clip holding the airbag in place.
    • Repeat on the opposite side to release the airbag.
  4. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 4, 2 resimden 1. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 4, 2 resimden 2.
    • Use a small flathead screwdriver to pop up the tabs on the airbag connector wires and disconnect them.
    • Disconnect the horn wire.
    • Carefully remove the airbag and set aside.
  5. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 5, 2 resimden 1. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 5, 2 resimden 2.
    • Use a socket wrench and 24mm socket to remove the steering wheel bolt.
  6. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 6, 1 resimden 1.
    • Unclip and disconnect the steering wheel wires at the top.
  7. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 7, 1 resimden 1.
    • Pull the steering wheel away from the steering column and set aside.
  8. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 8, 2 resimden 1. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 8, 2 resimden 2.
    • Use a socket wrench and 7mm socket to remove the three screws underneath the steering column that hold the two parts of the steering column covers in place.
    • Separate the steering column covers and push them aside to access the clockspring.
  9. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 9, 1 resimden 1.
    • Unscrew the broken clockspring using a T10 Torx screwdriver to remove the four screws holding it in place.
  10. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 10, 2 resimden 1. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 10, 2 resimden 2.
    • Remove the broken clockspring and set it aside.
  11. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 11, 2 resimden 1. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 11, 2 resimden 2.
    • Install the new clockspring using a T10 Torx screwdriver.
    • Replace the four screws and tighten them.
    • Remove the clockspring lock tab to release the new clockspring mechanism.
  12. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 12, 1 resimden 1.
    • Move the steering column covers back into place and replace the three screws underneath using a socket wrench and 7mm socket.
  13. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 13, 2 resimden 1. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 13, 2 resimden 2.
    • Feed the two airbag wires through the back of the steering wheel to begin replacing it.
    • Replace the steering wheel bolt and tighten it with a socket wrench and 24mm socket.
  14. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 14, 3 resimden 1. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 14, 3 resimden 2. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 14, 3 resimden 3.
    • Reconnect the horn wires and the airbag wires.
    • Push down the tabs on the airbag wire connectors to make sure the connection is good.
  15. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 15, 1 resimden 1.
    • Return the airbag to its place and push it to clip it back in place.
  16. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 16, 1 resimden 1.
    • Reconnect the battery cables.
  17. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 17, 2 resimden 1. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 17, 2 resimden 2.
    • Check for a successful installation by cranking the vehicle to see the Engine OK light indicator on the dashboard.
    • Check that the steering wheel control buttons work.
Bitiş Çizgisi
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 20
Her zaman: 67
