Ana içeriğe geç
2015 Ford Focus Brake Light Replacement
Megan Wettstein
Megan Wettstein ve 3 diğer katkıda bulunanlar
En son January 3, 2024 tarihinde güncellendi
25 dakika
Orta
Öne Çıkan Öğrenci Kılavuzu
If the brake light for your 2015 Ford Focus is not turning on when the brake is pressed, it is likely due to a burnt-out brake light.
This process does not require any additional tools besides a new LED light bulb. Repairing a tail light is a relatively simple process that people can accomplish at home.
Working with light bulbs instills a small risk of injury. Make sure that your car is off, the parking brake is engaged, and nothing is pressing on the brake to avoid injury.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. 2015 Ford Focus Brake Light Replacement, Brake Light: adım 1, 1 resimden 1.
    • Open the trunk up.
  2. 2015 Ford Focus Brake Light Replacement: adım 2, 3 resimden 1. 2015 Ford Focus Brake Light Replacement: adım 2, 3 resimden 2. 2015 Ford Focus Brake Light Replacement: adım 2, 3 resimden 3.
    • Find the black panel located behind the brake light in the trunk and remove the panel by sliding it off with a small amount of force with your hands.
  3. 2015 Ford Focus Brake Light Replacement: adım 3, 3 resimden 1. 2015 Ford Focus Brake Light Replacement: adım 3, 3 resimden 2. 2015 Ford Focus Brake Light Replacement: adım 3, 3 resimden 3.
    • Twist left to loosen and remove the two screws of the light panel.
  4. 2015 Ford Focus Brake Light Replacement: adım 4, 3 resimden 1. 2015 Ford Focus Brake Light Replacement: adım 4, 3 resimden 2. 2015 Ford Focus Brake Light Replacement: adım 4, 3 resimden 3.
    • Remove the exterior light panel by sliding it off with a small amount of force with both hands.
  5. 2015 Ford Focus Brake Light Replacement: adım 5, 3 resimden 1. 2015 Ford Focus Brake Light Replacement: adım 5, 3 resimden 2. 2015 Ford Focus Brake Light Replacement: adım 5, 3 resimden 3.
    • Twist the light bulb socket a quarter turn to the right to take out the light bulb compartment.
  6. 2015 Ford Focus Brake Light Replacement: adım 6, 2 resimden 1. 2015 Ford Focus Brake Light Replacement: adım 6, 2 resimden 2.
    • Pull out the old light bulb from the socket.
  7. 2015 Ford Focus Brake Light Replacement: adım 7, 3 resimden 1. 2015 Ford Focus Brake Light Replacement: adım 7, 3 resimden 2. 2015 Ford Focus Brake Light Replacement: adım 7, 3 resimden 3.
    • Push the new light bulb into the light bulb socket.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 18
Son 7 gün: 145
Son 30 gün: 431
Her zaman: 3,266
