2015-Present Nissan Maxima Headlight Bulb(s) Replacement
Giriş
1. adıma gitA non-functioning headlight can lead to hazardous road situations for you and other drivers. In this guide, you will learn to replace a damaged or not working headlight in a 2015-Present Nissan Maxima. Before beginning the repair ensure your engine is turned off and cool and the emergency brake is on. You will need the following tools to complete this repair:
- A flat-head screwdriver or nonmetal pry tool
- A 10mm socket wrench
Pull the hood release latch located on the lower left portion of your dashboard (near the steering wheel).
Fully release the hood latch by moving the yellow prop bar to the left.
Disconnect the battery connections from the terminals using the 10 mm socket wrench.
Remove the battery securing clamp by removing the following bolts:
Three 10mm bolts
Grabbing the battery by the handle, carefully lift it out of the vehicle.
Using a flathead screwdriver or nonmetal pry tool, gently pry up the following clips on the plastic covering:
10 plastic clips
Reaching through the battery area and to the back of the driver's side headlight, find the headlight bulb.
Twist the bulb to remove it from the headlight housing.
Once free, pull the headlight and cables up to the battery area.
Push the small tab on the wire clip to disconnect the bulb.
The tab is located on the side opposite of the bulb.
Install new bulb into wire clip. A click should be felt when it is properly seated.
Insert the bulb back into the headlight housing.
The bulb will be visible inside the headlight when installed correctly.
Remove the plastic clip holding the washer fluid tank in place using a flathead screwdriver or nonmetal pry tool.
Once free, remove the tank from the vehicle.
Remove and replace the passenger side bulb using the same steps as the driver's side.
Before reinserting the plastic clips for the plastic cover, they must each be separated into two pieces.
First, install the shorter, hollow piece into the hole until it is firmly seated.
Then, insert longer, solid piece into the hollow piece until it firmly snaps into place.
To complete the repair, reassemble all parts following instructions in reverse order.
