Ana içeriğe geç
2016 Prius Windshield Wiper Replacement
Mari Crampton
Mari Crampton ve 3 diğer katkıda bulunanlar
En son December 19, 2024 tarihinde güncellendi
5 - 10 dakika
Kolay
If the windshield wipers on your 2016 Toyota Prius are no longer clearing your windshield effectively or are showing signs of wear, use this guide to replace them. This process is straightforward and will restore proper visibility during rain and snow.
The windshield wipers on the 2016 Toyota Prius are essential for safe driving in inclement weather. Over time, wiper blades can become worn, cracked, or less effective, which compromises your ability to see clearly. This guide will show you how to safely remove the old wiper blades and install new ones.
Before starting, ensure your vehicle is parked on a flat surface and the ignition is off to avoid accidental wiper activation. Additionally, handle the wiper arms carefully to prevent them from snapping back and damaging the windshield.
This repair requires no special tools or skills, making it a beginner-friendly project. For additional maintenance tips or troubleshooting advice, visit the Toyota Owner's Manual or consult the manufacturer’s recommendations for compatible replacement wiper blades.
By following this guide, you’ll extend the life of your vehicle’s windshield wiper system and improve your driving safety in adverse conditions.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. 2016 Prius Windshield Wiper Replacement, Windshield Wiper: adım 1, 1 resimden 1.
    • Purchase the appropriate wiper blades for a 2016 Toyota Prius.
    • Typically, you’ll need a 26-inch blade for the driver side and a 16-inch blade for the passenger side.
    • Check the car’s manual or the packaging to confirm.
  2. 2016 Prius Windshield Wiper Replacement: adım 2, 1 resimden 1.
    • Wipe down the wiper arms and the surrounding area with a microfiber cloth.
  3. 2016 Prius Windshield Wiper Replacement: adım 3, 3 resimden 1. 2016 Prius Windshield Wiper Replacement: adım 3, 3 resimden 2. 2016 Prius Windshield Wiper Replacement: adım 3, 3 resimden 3.
    • Be cautious, as the arm is spring loaded and letting it snap back can crack the windshield or damage your wipers.
    • You can put a towel down against the windshield if damaging it is a concern.
    • Carefully pull the wiper arm away from the windshield until it locks in an upright position.
    • To remove the old wiper blade, press the small tab or release clip at the point where the wiper blade connects to the wiper arm and slide it off.
  4. 2016 Prius Windshield Wiper Replacement: adım 4, 2 resimden 1. 2016 Prius Windshield Wiper Replacement: adım 4, 2 resimden 2.
    • Open the new windshield wiper
    • Remove the incorrect adapter piece by firmly holding the wiper in one hand and use upward force to pry it off.
  5. 2016 Prius Windshield Wiper Replacement: adım 5, 3 resimden 1. 2016 Prius Windshield Wiper Replacement: adım 5, 3 resimden 2. 2016 Prius Windshield Wiper Replacement: adım 5, 3 resimden 3.
    • Find the bag of additional adapter pieces that come with the windshield wiper and pull out the one labeled #6.
    • Make sure the guidance arrows are pointing in the same direction.
    • To attach the #6 adapter, align the adapter and blade and push using downward force until you hear them click into place.
  6. 2016 Prius Windshield Wiper Replacement: adım 6, 2 resimden 1. 2016 Prius Windshield Wiper Replacement: adım 6, 2 resimden 2.
    • Now that the correct adapter is attached, align the new wiper blade with the hook on the wiper arm.
    • Slide the wiper blade in until you hear a click, indicating it’s securely locked in place.
    • Double-check that it’s fastened to avoid it detaching while in use.
  7. 2016 Prius Windshield Wiper Replacement: adım 7, 1 resimden 1.
    • Slowly lower the wiper arm back onto the windshield.
    • Be gentle, as the arm can snap back if released quickly, potentially damaging the windshield or the new blade.
    • To change the second windshield wiper blade, repeat steps 2-6
Sonuç
Congratulations, you've learned how to successfully replace your windshield wipers! Safe driving!
Mari Crampton
175 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 1-1, Vidal-Chiesa Fall 2024 UC Davis, Team 1-1, Vidal-Chiesa Fall 2024 üyesi
UCD-VIDAL-CHIESA-F24S1G1
3 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 57
Her zaman: 181
