Ana içeriğe geç
2021 Honda HR-V Rear Signal Light Bulb Replacement
Neye ihtiyacın var
  1. 2021 Honda HR-V Rear Signal Light Bulb Replacement, Rear Signal Light Bulb: adım 1, 1 resimden 1.
    • Press the tailgate release button and lift open the rear hatch.
  2. 2021 Honda HR-V Rear Signal Light Bulb Replacement: adım 2, 3 resimden 1. 2021 Honda HR-V Rear Signal Light Bulb Replacement: adım 2, 3 resimden 2. 2021 Honda HR-V Rear Signal Light Bulb Replacement: adım 2, 3 resimden 3.
    • Remove the two screws beside each tail light assembly (four total) using a Phillips #1 screwdriver.
  3. 2021 Honda HR-V Rear Signal Light Bulb Replacement: adım 3, 2 resimden 1. 2021 Honda HR-V Rear Signal Light Bulb Replacement: adım 3, 2 resimden 2.
    • Place both hands on the tail light assembly and pull it directly outwards (away from the vehicle).
    • The tail light assembly will still be connected to the vehicle by wiring, so make sure to be careful when pulling the light assembly out.
  4. 2021 Honda HR-V Rear Signal Light Bulb Replacement: adım 4, 3 resimden 1. 2021 Honda HR-V Rear Signal Light Bulb Replacement: adım 4, 3 resimden 2. 2021 Honda HR-V Rear Signal Light Bulb Replacement: adım 4, 3 resimden 3.
    • Remove the rear signal light bulb from the light assembly by rotating the bulb socket counterclockwise.
  5. 2021 Honda HR-V Rear Signal Light Bulb Replacement: adım 5, 2 resimden 1. 2021 Honda HR-V Rear Signal Light Bulb Replacement: adım 5, 2 resimden 2.
    • Pull apart the light bulb from its socket.
    • Replace with a new light bulb and apply pressure to ensure the light bulb is securely fastened.
  6. 2021 Honda HR-V Rear Signal Light Bulb Replacement: adım 6, 3 resimden 1. 2021 Honda HR-V Rear Signal Light Bulb Replacement: adım 6, 3 resimden 2. 2021 Honda HR-V Rear Signal Light Bulb Replacement: adım 6, 3 resimden 3.
    • Slide the light assembly into the raised white plastic attached to the vehicle.
    • Align the holes on the light assembly to the holes on the vehicle and fasten the bolts into position.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Guadalupe Guevara
157 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 20
Son 7 gün: 45
Son 30 gün: 61
Her zaman: 1,546
