Ana içeriğe geç
3DR Iris Plus Quadcopter Propeller Replacement
Neye ihtiyacın var
  1. 3DR Iris Plus Quadcopter Propeller Replacement, Battery: adım 1, 1 resimden 1.
    • Power off the drone by holding down the power button.
    • Remove the battery by disconnecting it from the main battery connector.
    • Press the power button again to ensure all electricity is discharged.
    • This step is imperative as it is dangerous to handle drone components with a running current!
  2. 3DR Iris Plus Quadcopter Propeller Replacement, Propeller: adım 2, 2 resimden 1. 3DR Iris Plus Quadcopter Propeller Replacement, Propeller: adım 2, 2 resimden 2.
    • Take note of the propeller cap color (either black or silver).
    • Hold down the motor assembly and twist the propeller clockwise to unlock it (you should feel some resistance until it starts to unscrew freely).
    • Hold down the motor assembly and twist the propeller counterclockwise to unlock it (you should feel some resistance until it starts to unscrew freely).
    • This is the motor assembly.
  3. 3DR Iris Plus Quadcopter Propeller Replacement: adım 3, 2 resimden 1. 3DR Iris Plus Quadcopter Propeller Replacement: adım 3, 2 resimden 2.
    • Ensure that the propeller cap color (black or silver) matches the propeller screw cap color.
    • There are two different types of propellers so make sure you're using the correct one.
Sonuç
To reassemble your device, follow these directions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Wanjiku Gichigi
196 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G5, Regan Winter 2020 Cal Poly, Team S7-G5, Regan Winter 2020 üyesi
CPSU-REGAN-W20S7G5
5 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 356
