Ana içeriğe geç
4Sight 9 Battery Replacement
Neye ihtiyacın var
    1. 4Sight 9 Battery Replacement, Cover: adım 1, 2 resimden 1. 4Sight 9 Battery Replacement, Cover: adım 1, 2 resimden 2.
      • Place the tablet on its side so that the two screws are facing upward.
      • Remove two 1 mm screws from the left side of the tablet using a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. 4Sight 9 Battery Replacement: adım 2, 1 resimden 1.
      • Pry the case away from the device slowly by sliding a plastic opening tool along the device.
      • Once loosened, use your hands to separate the case from the device.
      FixBot'a Sor
      Yorum Ekle
    3. 4Sight 9 Battery Replacement: adım 3, 2 resimden 1. 4Sight 9 Battery Replacement: adım 3, 2 resimden 2.
      • Hold the positive and negative wires as close as possible to the speaker.
      • Use an opening tool and fingers to simultaneously lift the speaker from the cover.
      FixBot'a Sor
      Yorum Ekle
    1. 4Sight 9 Battery Replacement, Battery: adım 4, 1 resimden 1.
      • Use soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
      • For a complete guide on how to solder, click here.
      FixBot'a Sor
      Yorum Ekle
    2. 4Sight 9 Battery Replacement: adım 5, 2 resimden 1. 4Sight 9 Battery Replacement: adım 5, 2 resimden 2.
      • Insert plastic prying tool under upper-hand corner of battery and slide back and forth.
      • Once loosened, insert plastic prying tool under lower-hand corner and repeat sliding action.
      • Repeat previous actions until battery comes loose from device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 43
Her zaman: 2,232
