Giriş
You need plastic prying tools and a 1mm screwdriver. Anticipate roughly 10-15 minutes for this procedure. Be sure to have a cleared out space.
Neye ihtiyacın var
Place the tablet on its side so that the two screws are facing upward.
Remove two 1 mm screws from the left side of the tablet using a Phillips #00 screwdriver.
Use soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
Bir başkası bu kılavuzu tamamladı.
