Ana içeriğe geç
6. Installing Klipper Screen
David Husolo
David Husolo ve başka bir katkıda bulunan
En son April 15, 2023 tarihinde güncellendi
Tahmin yok
Orta
Topluluk-Katkılı Kılavuz
In this guide I will show you how to setup Klipper screen on a Big Tree Tech PiTFT50 screen.
  1. 6. Installing Klipper Screen, 6. Installing Klipper Screen: adım 1, 1 resimden 1.
    • You need to set the OS to boot to console
    • sudo raspi-config
    • 1 System Options > S5 Boot / Auto Login > B1 Console. Then reboot
    • Download and install KlipperScreen
    • git clone https://github.com/jordanruthe/KlipperSc...
    • cd ~/KlipperScreen
    • ./scripts/KlipperScreen-install.sh
    • When the install is finished reboot the RPI. This will take some time to install so feel free to get yourself a cold beverage and relax for a little bit.
  2. 6. Installing Klipper Screen: adım 2, 1 resimden 1.
    • If you loaded my config files it should already be included but check moonraker.conf contains:
    • [authorization] under trusted clients contains 127.0.0.1
    • [update manager KlipperScreen]
  3. 6. Installing Klipper Screen: adım 3, 2 resimden 1. 6. Installing Klipper Screen: adım 3, 2 resimden 2.
    • If you used the latest version of Mainsail(v7.0) skip this next command.
    • git clone https://github.com/mainsail-crew/moonrak...
    • Regardless if you used the latest version or not run
    • bash ~/moonraker-timelapse/install.sh
    • Make sure printer.cfg calls the timelapse config
    • [include timelapse.cfg]
    • Make sure the [timelapse] section is uncommented in moonraker.conf
Bitiş Çizgisi
David Husolo
9.162 İtibar
33 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 1,799
