Ana içeriğe geç
8BitDo SN30 Pro+ Controller Joystick Caps Replacement
Neye ihtiyacın var
  1. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Battery: adım 1, 3 resimden 1. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Battery: adım 1, 3 resimden 2. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Battery: adım 1, 3 resimden 3.
    • Place the controller face down.
    • Remove the battery cover.
    • Remove rechargeable battery or AA batteries.
  2. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Trigger Buttons: adım 2, 2 resimden 1. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Trigger Buttons: adım 2, 2 resimden 2.
    • Remove L2 and R2 trigger buttons by pushing them away from the grips.
  3. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Screws: adım 3, 2 resimden 1. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Screws: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use Tweezers to uncover two screws under the label in the battery compartment.
    • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
  4. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Unclip Covers: adım 4, 3 resimden 1. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Unclip Covers: adım 4, 3 resimden 2. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Unclip Covers: adım 4, 3 resimden 3.
    • At the end of each grip, pry apart the covers.
    • Use fingernail or opening pick to undo the two top clips.
    • One clip next to L button.
    • One clip next to R button
    • Undo the final clip between the joysticks.
  5. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Separate Covers: adım 5, 1 resimden 1.
    • Carefully move the rear cover away and from the front cover. Place it to the left.
    • Do not completely separate. The two halves are still attached via a white ribbon cable.
    I just used this guide to open a Pro2 controller, the only difference was the ribbon cable was between the analog sticks. Otherwise it went perfectly.
    Dunch - Yanıt
    You have to be careful not to break the clip on the middle bottom (between the analog sticks)
    Kelvie Wong - Yanıt
  6. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Caps: adım 6, 3 resimden 1. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Caps: adım 6, 3 resimden 2. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Caps: adım 6, 3 resimden 3.
    • Grab the top and pull straight up on the joystick cap. Pulling out the caps one-by-one.
  7. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Installing New Caps: adım 7, 3 resimden 1. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Installing New Caps: adım 7, 3 resimden 2. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Installing New Caps: adım 7, 3 resimden 3.
    • One at a time, Orient the new cap to match the analog stick.
    • Push the cap straight down onto the analog stick.
    • You should hear the click of the stick button
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Brian W
1.692 İtibar
8 adet Kılavuz yazıldı
5Kılavuz Yorumları
Was wondering, does other brand joystick cap other than 8bitdo (eg:ps4, ps5, xbox one) fits ?
Lee Han Chang - Yanıt
looks like PS5 hole size and cone shape. Confirmation needed.
Gustavo Klein Martins -
I did the repair with a third party analog cap meant for the PS5 (being extra cheap) on the Pro 2. Despite the bottom hole being bigger on the original, the replacement joystick fit right in.
TorxT6 -
Did you manage to find a replacement? Looking for an alternative as well since 8bitdo doesn't ship here.
Joseph Johansson - Yanıt
Hello Joseph, I've purchased my replacements from Core Electronics with no issues, how ever they are based in Australia so unsure if they will ship to where you need them.
Darryn Stanmore -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 98
Her zaman: 3,852
