Ana içeriğe geç
8BitDo Ultimate Wireless Button Conductive Pad Replacement
Neye ihtiyacın var
  1. 8BitDo Ultimate Wireless Button Conductive Pad Replacement, Case: adım 1, 2 resimden 1. 8BitDo Ultimate Wireless Button Conductive Pad Replacement, Case: adım 1, 2 resimden 2.
    • Insert an opening pick into the seam between the left controller grip and main controller body.
    • Pry the grip off.
    • Repeat for the right grip.
    FixBot'a Sor
    Yorum Ekle
  2. 8BitDo Ultimate Wireless Button Conductive Pad Replacement: adım 2, 2 resimden 1. 8BitDo Ultimate Wireless Button Conductive Pad Replacement: adım 2, 2 resimden 2.
    • Remove the six 8 mm T6 Torx screws securing the rear case to the front case.
    FixBot'a Sor
    Yorum Ekle
  3. 8BitDo Ultimate Wireless Button Conductive Pad Replacement: adım 3, 3 resimden 1. 8BitDo Ultimate Wireless Button Conductive Pad Replacement: adım 3, 3 resimden 2. 8BitDo Ultimate Wireless Button Conductive Pad Replacement: adım 3, 3 resimden 3.
    • Insert an opening tool into seam at the bottom of the device and carefully pry the front and back shells apart.
    • Set the halves next to each other with care not to strain the connected ribbon cables.
    FixBot'a Sor
    Yorum Ekle
  4. 8BitDo Ultimate Wireless Button Conductive Pad Replacement: adım 4, 3 resimden 1. 8BitDo Ultimate Wireless Button Conductive Pad Replacement: adım 4, 3 resimden 2. 8BitDo Ultimate Wireless Button Conductive Pad Replacement: adım 4, 3 resimden 3.
    • The ribbon cable is secured with a locking tab connector.
    • Use tweezers to unlock the locking tab on the ribbon cable connector, then gently disconnect the ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  5. 8BitDo Ultimate Wireless Button Conductive Pad Replacement, Button Conductive Pad: adım 5, 2 resimden 1. 8BitDo Ultimate Wireless Button Conductive Pad Replacement, Button Conductive Pad: adım 5, 2 resimden 2.
    • Remove the seven 5 mm Phillips #00 screws securing the PCB to the top shell.
    • Lift the PCB out.
    FixBot'a Sor
    Yorum Ekle
  6. 8BitDo Ultimate Wireless Button Conductive Pad Replacement: adım 6, 2 resimden 1. 8BitDo Ultimate Wireless Button Conductive Pad Replacement: adım 6, 2 resimden 2.
    • Lift button conductive pads out of the shell with your hands.
    • Replace or clean as needed.
    • If cleaning with water, make sure pads are fully dry before replacing.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
John Sweriduk
85 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-3, Biswokarma Spring 2026 UMass Dartmouth, Team 1-3, Biswokarma Spring 2026 üyesi
UMASSD-BISWOKARMA-S26S1G3
5 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 45
Her zaman: 138
