Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. ALCATEL 5015A Pixi 3 (5) 3G cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. ALCATEL 5015A Pixi 3 (5) 3G Teardown, Remove the inside panel - screws: adım 1, 2 resimden 1. ALCATEL 5015A Pixi 3 (5) 3G Teardown, Remove the inside panel - screws: adım 1, 2 resimden 2.
    • Once you have the back removed and the battery set aside, you have 4 (long screws) at the corners, and 4 (smaller) screws in the middle. Set these aside in a safe place. (I used the back of the phone itself)
  2. ALCATEL 5015A Pixi 3 (5) 3G Teardown, Separating the rear frame.: adım 2, 3 resimden 1. ALCATEL 5015A Pixi 3 (5) 3G Teardown, Separating the rear frame.: adım 2, 3 resimden 2. ALCATEL 5015A Pixi 3 (5) 3G Teardown, Separating the rear frame.: adım 2, 3 resimden 3.
    • Find a small crevice along the outside and carefully insert your spudger, small screw driver or guitar pick tool inside and slide it along the length of the side to seperate the front assembly from the rear.
    • Carefully work the opposite side as well, you will need to duplicate while being mindful of the circuit board.
  3. ALCATEL 5015A Pixi 3 (5) 3G Teardown: adım 3, 1 resimden 1.
    • Take care not to damage the ribbon cable connectors (red arrows) coming from the front display assembly attempting to lift the circuit board from the display.
    • The guitar pick tool (orange arrows) should slide easily under the circuit board except for where the cables might still be connected.
  4. ALCATEL 5015A Pixi 3 (5) 3G Teardown, Camera & Cables: adım 4, 2 resimden 1. ALCATEL 5015A Pixi 3 (5) 3G Teardown, Camera & Cables: adım 4, 2 resimden 2.
    • Carefully remove the rear facing camera (pink box) and lift the speaker upwards (blue box - do not try to disconnect). The speaker is held in place by the magnet on the backside. You may need flat edge under the side to separate it from the plate of metal.
    • Carefully seperate the ribbon attachment from the top (red box) to remove the front facing camera (adhered to the front) with a small piece of adhesion.
  5. ALCATEL 5015A Pixi 3 (5) 3G Teardown, Cables continued...: adım 5, 2 resimden 1. ALCATEL 5015A Pixi 3 (5) 3G Teardown, Cables continued...: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Carefully lift (with tweezers or small pliers) the connection indicated by the yellow box(s)
    • Next lift, with tweezers or spudger (carefully) the connection indicated by the blue box marker.
    • You will need a flat surface to lift carefully the clip which holds the connector indicated by the green box. You can then use a pair of tweezers (or your fingernails?) to slide the connector to the side.
  6. ALCATEL 5015A Pixi 3 (5) 3G Teardown, Separate the circuit board: adım 6, 3 resimden 1. ALCATEL 5015A Pixi 3 (5) 3G Teardown, Separate the circuit board: adım 6, 3 resimden 2. ALCATEL 5015A Pixi 3 (5) 3G Teardown, Separate the circuit board: adım 6, 3 resimden 3.
    • The circuit board should separate with little or no effort.
    • The orange box marker shows sighs of water damage. This phone had been dropped in a puddle.
Thomas Keats
343 İtibar
1 Kılavuz yazıldı
Ekip
Rainbow Computers Rainbow Computers üyesi
Business
1 Üye
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 29
Her zaman: 3,514
