Ana içeriğe geç
Yardım
ALCATEL 5015A Pixi 3 (5) 3G Teardown
Adım 5 Düzenleniyor —
Adım Tipi:
Yeniden düzenlemek için sürükleyin
Carefully lift (with tweezers or small pliers) the connection indicated by the yellow box(s)
Next lift, with tweezers or spudger (carefully) the connection indicated by the blue box marker.
You will need a flat surface to lift carefully the clip which holds the connector indicated by the green box. You can then use a pair of tweezers (or your fingernails?) to slide the connector to the side.
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
