Ana içeriğe geç
APEX TM785CH Speakers Replacement
Neye ihtiyacın var
  1. APEX TM785CH Speakers Replacement, Back Casing: adım 1, 2 resimden 1. APEX TM785CH Speakers Replacement, Back Casing: adım 1, 2 resimden 2.
    • Start by bending the tablet back at the top white-colored portion to expose an opening between the back cover and the tablet body.
    • Wedge a plastic opening tool into the opening and push it down to force the back cover off.
    • Move along the top edge of the tablet and repeat the step above.
    • Pull the back cover away from the tablet body to completely remove it.
  2. APEX TM785CH Speakers Replacement, Speakers: adım 2, 3 resimden 1. APEX TM785CH Speakers Replacement, Speakers: adım 2, 3 resimden 2. APEX TM785CH Speakers Replacement, Speakers: adım 2, 3 resimden 3.
    • The speakers are located towards the bottom left and bottom right corners of the tablet.
    • If not already done, remove the black tape holding the wires down.
    • Wedge a spudger underneath the speaker in its socket, near where the wires are connected. You can then pry out the speakers.
  3. APEX TM785CH Speakers Replacement: adım 3, 2 resimden 1. APEX TM785CH Speakers Replacement: adım 3, 2 resimden 2.
    • You will need a soldering/desoldering kit to desolder the 4 leads where the speakers connect to the circuit board.
Sonuç
Brian Graschel
823 İtibar
6 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-1, Williams Spring 2015 Baylor, Team 4-1, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S4G1
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 2,586
