Ana içeriğe geç
ASUS PadFone X Power and Volume Buttons Replacement
Madeline Dement
Madeline Dement ve 4 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
15 - 25 dakika
Orta
Eksik önkoşulları
Buttons on your phone sticking or not working? Here's how to replace them!
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. ASUS PadFone X Power and Volume Buttons Replacement, Power and Volume Buttons: adım 1, 1 resimden 1.
    • Pry off the back cover with the blue plastic opening tool.
    • Removing the cover may require a bit of force.
  2. ASUS PadFone X Power and Volume Buttons Replacement: adım 2, 1 resimden 1.
    • Remove thirteen 3.6mm screws using the T5 Torx Screwdriver.
  3. ASUS PadFone X Power and Volume Buttons Replacement: adım 3, 1 resimden 1.
    • Once the screws are removed, the mid-frame can be lifted off of the phone.
  4. ASUS PadFone X Power and Volume Buttons Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Grasp the button strip with tweezers.
    • Pull the buttons upwards gently. The buttons should remove easily.
  5. ASUS PadFone X Power and Volume Buttons Replacement: adım 5, 1 resimden 1.
    • Use the blue plastic opening tool to disconnect the orange sensor strip.
    • Applying too much force may damage the connector.
  6. ASUS PadFone X Power and Volume Buttons Replacement: adım 6, 1 resimden 1.
    • Grasp the sensor with the tweezers.
    • Pull outwards away from the phone.
    • The sensor is held on by adhesive. You will need to apply some force when removing.
Sonuç
Madeline Dement
114 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 2-1, Baechle Spring 2017 IUPUI, Team 2-1, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S2G1
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 297
