Ana içeriğe geç
ASUS ROG Spatha X Scroll Wheel Replacement
Neye ihtiyacın var
    1. ASUS ROG Spatha X Scroll Wheel Replacement, Mouse Cover: adım 1, 3 resimden 1. ASUS ROG Spatha X Scroll Wheel Replacement, Mouse Cover: adım 1, 3 resimden 2. ASUS ROG Spatha X Scroll Wheel Replacement, Mouse Cover: adım 1, 3 resimden 3.
      • Make sure the mouse is unplugged and the power switch on the underside is set to the off position.
      • Use the pointed edge of a spudger to remove the four soft rubber covers on the underside of the mouse.
      • Use the included Torx screwdriver, or a T3 Torx screwdriver, to remove the four 4 mm screws.
      FixBot'a Sor
      Yorum Ekle
    2. ASUS ROG Spatha X Scroll Wheel Replacement: adım 2, 2 resimden 1. ASUS ROG Spatha X Scroll Wheel Replacement: adım 2, 2 resimden 2.
      • Lift the upper mouse cover up and off.
      FixBot'a Sor
      Yorum Ekle
    1. ASUS ROG Spatha X Scroll Wheel Replacement, Scroll Wheel: adım 3, 3 resimden 1. ASUS ROG Spatha X Scroll Wheel Replacement, Scroll Wheel: adım 3, 3 resimden 2. ASUS ROG Spatha X Scroll Wheel Replacement, Scroll Wheel: adım 3, 3 resimden 3.
      • Remove the Phillips screw securing the ribbon cable scroll wheel.
      • Disconnect the ribbon cable from the scroll wheel.
      FixBot'a Sor
      Yorum Ekle
    2. ASUS ROG Spatha X Scroll Wheel Replacement: adım 4, 3 resimden 1. ASUS ROG Spatha X Scroll Wheel Replacement: adım 4, 3 resimden 2. ASUS ROG Spatha X Scroll Wheel Replacement: adım 4, 3 resimden 3.
      • There is a plastic axle holding the scroll wheel in place. It is cinched into a plastic housing unit towards the right side of the mouse (towards the pinky rest).
      • Use one hand to gently pull the housing for the axle away from the scroll wheel as you simultaneously use the other hand to pull up and away from the housing unit.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
cgrabowski1
678 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-4, Botvin Spring 2025 UMass Dartmouth, Team 3-4, Botvin Spring 2025 üyesi
UMASSD-BOTVIN-S25S3G4
3 Üyeler
1Rehber Yorum
Easy replacement but good luck finding the part. It's not sold ANYWHERE.
Tyler Pratt - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 26
Son 30 gün: 118
Her zaman: 1,186
