Ana içeriğe geç
ASUS ROG Spatha X Switch Replacement
Neye ihtiyacın var
    1. ASUS ROG Spatha X Switch Replacement, Mouse Cover: adım 1, 3 resimden 1. ASUS ROG Spatha X Switch Replacement, Mouse Cover: adım 1, 3 resimden 2. ASUS ROG Spatha X Switch Replacement, Mouse Cover: adım 1, 3 resimden 3.
      • Make sure the mouse is unplugged and the power switch on the underside is set to the off position.
      • Use the pointed edge of a spudger to remove the four soft rubber covers on the underside of the mouse.
      • Use the included Torx screwdriver, or a T3 Torx screwdriver, to remove the four 4 mm screws.
      FixBot'a Sor
      Yorum Ekle
    2. ASUS ROG Spatha X Switch Replacement: adım 2, 2 resimden 1. ASUS ROG Spatha X Switch Replacement: adım 2, 2 resimden 2.
      • Lift the upper mouse cover up and off.
      FixBot'a Sor
      Yorum Ekle
    1. ASUS ROG Spatha X Switch Replacement, Switch: adım 3, 3 resimden 1. ASUS ROG Spatha X Switch Replacement, Switch: adım 3, 3 resimden 2. ASUS ROG Spatha X Switch Replacement, Switch: adım 3, 3 resimden 3.
      • Remove the switch(es) you'd like to swap out by gently grabbing them on either side and pulling straight up.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
cgrabowski1
678 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-4, Botvin Spring 2025 UMass Dartmouth, Team 3-4, Botvin Spring 2025 üyesi
UMASSD-BOTVIN-S25S3G4
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 75
Her zaman: 751
