Giriş
Use this guide to replace the SSD on your ASUS TUF Dash F15.
Before you perform this repair, if at all possible, back up your existing SSD. If you are replacing the SSD where your operating system is installed, familiarize yourself with a disk cloning utility so you’ll be ready to migrate your data to the new SSD.
Be sure to completely power off and unplug your laptop. Make sure the laptop is not in standby, sleep, or hibernation mode.
Neye ihtiyacın var
Remove the 14 Phillips screws securing the lower case:
Seven 8.8 mm screws
Seven 10.1 mm screws
Use a Phillips screwdriver to loosen the captive screw.
Insert an opening pick between the lower case and the chassis on the front right edge near the captive screw.
Slide the pick along the front edge to release the clips securing the lower case.
Repeat this process along the perimeter of the lower case to release the remaining clips.
Use tweezers or your fingers to peel back the tape on the battery connector.
Use the flat end of a spudger to gently push the locking bar away from the battery connector.
Insert the pointed end of a spudger under the battery connector.
Pry under the left edge of the battery connector to disconnect the left side of the connector.
Repeat this procedure for the right side of the connector.
Use a Phillips screwdriver to remove the 4.2 mm screw securing the SSD.
Pull the SSD out of its socket and remove it. Keep the SSD as parallel to the motherboard as possible when pulling on it.
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our ASUS TUF answers community for help.
5 farklı kişi bu kılavuzu tamamladı.
