Ana içeriğe geç
ASUS Transformer Book Flip TP500LA Fan Replacement
Neye ihtiyacın var
    1. ASUS Transformer Book Flip TP500LA Fan Replacement, Back Case: adım 1, 3 resimden 1. ASUS Transformer Book Flip TP500LA Fan Replacement, Back Case: adım 1, 3 resimden 2. ASUS Transformer Book Flip TP500LA Fan Replacement, Back Case: adım 1, 3 resimden 3.
      • Remove the ten 10 mm Phillips #0 screws found on the computer's back case.
      FixBot'a Sor
      Yorum Ekle
    2. ASUS Transformer Book Flip TP500LA Fan Replacement: adım 2, 2 resimden 1. ASUS Transformer Book Flip TP500LA Fan Replacement: adım 2, 2 resimden 2.
      Bu adımda kullanılan alet:
      Heavy-Duty Spudger
      • Slide a heavy-duty spudger between the back case and the computer.
      • Slowly work around the edges to undo the clips to fully separate the back case from the computer.
      • Gently lift off the back case.
      FixBot'a Sor
      Yorum Ekle
    1. ASUS Transformer Book Flip TP500LA Fan Replacement, Battery: adım 3, 2 resimden 1. ASUS Transformer Book Flip TP500LA Fan Replacement, Battery: adım 3, 2 resimden 2.
      Heavy-Duty Spudger
      • Slide a heavy-duty spudger into the ZIF connector and gently flip up the retaining flap to open the connector.
      • Pull the blue tab to remove the ribbon.
      FixBot'a Sor
      Yorum Ekle
    2. ASUS Transformer Book Flip TP500LA Fan Replacement: adım 4, 2 resimden 1. ASUS Transformer Book Flip TP500LA Fan Replacement: adım 4, 2 resimden 2.
      • Remove the three 5 mm Phillips #0 screws.
      • Remove the single 6 mm Phillips #0 screw.
      FixBot'a Sor
      Yorum Ekle
    3. ASUS Transformer Book Flip TP500LA Fan Replacement: adım 5, 2 resimden 1. ASUS Transformer Book Flip TP500LA Fan Replacement: adım 5, 2 resimden 2.
      • Use the heavy-duty spudger to pry the white 8-pin connector away from the motherboard.
      • Gently pull the connector away from the motherboard.
      • The black 8-pin connector on the motherboard is very fragile, so be careful when removing the white 8-pin connector.
      FixBot'a Sor
      Yorum Ekle
    4. ASUS Transformer Book Flip TP500LA Fan Replacement: adım 6, 2 resimden 1. ASUS Transformer Book Flip TP500LA Fan Replacement: adım 6, 2 resimden 2.
      • Use the blue plastic opening tool to loosen and remove the three black wires from the battery.
      • Slide the battery out from the computer to remove.
      FixBot'a Sor
      Yorum Ekle
    1. ASUS Transformer Book Flip TP500LA Fan Replacement, Fan: adım 7, 2 resimden 1. ASUS Transformer Book Flip TP500LA Fan Replacement, Fan: adım 7, 2 resimden 2.
      • Unscrew the six 5 mm Phillips #0 screws.
      FixBot'a Sor
      Yorum Ekle
    2. ASUS Transformer Book Flip TP500LA Fan Replacement: adım 8, 3 resimden 1. ASUS Transformer Book Flip TP500LA Fan Replacement: adım 8, 3 resimden 2. ASUS Transformer Book Flip TP500LA Fan Replacement: adım 8, 3 resimden 3.
      • Grasp the top of the 3-pin connector with tweezers.
      • Wiggle the connector until it loosens itself from the motherboard.
      • Gently lift the connector from the motherboard attachment.
      FixBot'a Sor
      Yorum Ekle
    3. ASUS Transformer Book Flip TP500LA Fan Replacement: adım 9, 1 resimden 1.
      • Carefully lift the fan off the motherboard.
      • Attached to the fan is thermal pasting that needs to be reapplied when attaching the fan back to the motherboard. Follow this guide to reapply thermal pasting correctly.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Solomon Dovinh
435 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S13-G5, Forte Spring 2017 Cal Poly, Team S13-G5, Forte Spring 2017 üyesi
CPSU-FORTE-S17S13G5
3 Üyeler
40 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 30
Her zaman: 2,302
