Giriş
If your device is not operating normally or if you experience the blue screen of death (BSoD), it may be time to replace the motherboard. Follow these instructions to replace the motherboard in the ASUS Transformer Book Flip TP500LA.
Neye ihtiyacın var
Slide a heavy-duty spudger between the back case and the computer.
Slowly work around the edges to undo the clips to fully separate the back case from the computer.
Gently lift off the back case.
Slide a heavy-duty spudger into the ZIF connector and gently flip up the retaining flap to open the connector.
Pull the blue tab to remove the ribbon.
