Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Place the laptop upside down so that the bottom panel is facing upwards.
Unscrew the following 10 screws
Eight 5 mm Phillips head screws
Two 10 mm Phillips head screws
Carefully peel the panel off of the bottom of the laptop.
Remove the following 6 screws:
Two 5 mm screws holding the fan down.
Four 3 mm screws holding the heat sink down
Carefully disconnect the only sliding connector by using a plastic opening tool to pry the connector out.
Remove the tape holding the fan and heat sink together.
