Ana içeriğe geç
ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement
Neye ihtiyacın var
  1. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement, Battery: adım 1, 1 resimden 1.
    • Unscrew the (10) screws on the bottom of the computer chassis using the JIS #0 screwdriver.
  2. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: adım 2, 2 resimden 1. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: adım 2, 2 resimden 2.
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: adım 3, 3 resimden 1. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: adım 3, 3 resimden 2. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: adım 3, 3 resimden 3.
    • Remove the (6) six screws attaching the battery to the frame using the JIS #0 screwdriver.
    • Use the black plastic spudger to remove the battery from the device.
  4. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: adım 4, 3 resimden 1. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: adım 4, 3 resimden 2. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: adım 4, 3 resimden 3.
    • Gently take the battery out of the laptop, making sure that all wires connecting to it are disconnected.
  5. Dikkatli ol: adımlar 5-6 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
    ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement, Motherboard: adım 5, 2 resimden 1. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement, Motherboard: adım 5, 2 resimden 2.
    • When removing the cooling fan, carefully unplug the cable that is connected to the motherboard.
    • Once you have carefully unplugged the cable, the cooling fan should just come off with ease.
  6. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: adım 6, 2 resimden 1. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: adım 6, 2 resimden 2.
    • Carefully remove the motherboard.
    • You can now replace it with a new motherboard or perform any necessary modifications to it.
  7. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement, Charging Port: adım 7, 1 resimden 1.
Sonuç
Jens Peter Andersen
658 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G1, Walkup Fall 2017 USF Tampa, Team S5-G1, Walkup Fall 2017 üyesi
USFT-WALKUP-F17S5G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 1,008
