Ana içeriğe geç
ASUS ZENFONE 3 Zoom Motherboard Replacement
Neye ihtiyacın var
  1. ASUS ZENFONE 3 Zoom  Motherboard Replacement, Motherboard: adım 1, 2 resimden 1. ASUS ZENFONE 3 Zoom  Motherboard Replacement, Motherboard: adım 1, 2 resimden 2.
    • Use the sim card attachment for the screwdriver found in the IFIXIT box to remove the sim card tray from the phone.
  2. ASUS ZENFONE 3 Zoom  Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the 3.5 mm screws on both sides of the charging port, at the bottom of the phone, using the T2 screwdriver.
  3. ASUS ZENFONE 3 Zoom  Motherboard Replacement: adım 3, 2 resimden 1. ASUS ZENFONE 3 Zoom  Motherboard Replacement: adım 3, 2 resimden 2.
    • Use the opening tool to separate the screen and the plastic body of the phone.
  4. ASUS ZENFONE 3 Zoom  Motherboard Replacement: adım 4, 1 resimden 1.
    • Utilize the PH #00 attachment to remove the 3.3 mm screws in the bracket to the top left of the battery.
  5. ASUS ZENFONE 3 Zoom  Motherboard Replacement: adım 5, 1 resimden 1.
    • After removing the bracket and screws, pull up on the battery from the bottom of the unit and set aside.
  6. ASUS ZENFONE 3 Zoom  Motherboard Replacement: adım 6, 2 resimden 1. ASUS ZENFONE 3 Zoom  Motherboard Replacement: adım 6, 2 resimden 2.
    • Remove all three screws near the top of the phone with the PH #00.
    • The top right and left screws are 3.25 mm.
    • The middle screw is 2.65 mm.
  7. ASUS ZENFONE 3 Zoom  Motherboard Replacement: adım 7, 1 resimden 1.
    • De-solder the single black speaker wire attached to the left side of the phone.
  8. ASUS ZENFONE 3 Zoom  Motherboard Replacement: adım 8, 2 resimden 1. ASUS ZENFONE 3 Zoom  Motherboard Replacement: adım 8, 2 resimden 2.
    • Use the flat-edge side of iFixIt plastic spudger to detach both the ribbon connectors off the motherboard at their connection point.
  9. ASUS ZENFONE 3 Zoom  Motherboard Replacement: adım 9, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the tweezers to lift up on the edges of the motherboard located above where the battery, and remove the motherboard.
  10. ASUS ZENFONE 3 Zoom  Motherboard Replacement: adım 10, 1 resimden 1.
    • The finished product should be a motherboard with no connections to the body of the phone.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Saif Aiman
243 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S2-G3, Harley Summer 2019 IUPUI, Team S2-G3, Harley Summer 2019 üyesi
IUPUI-HARLEY-SU19S2G3
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 759
