Ana içeriğe geç
AT&T NVG510 Button Replacement
Neye ihtiyacın var
  1. AT&T NVG510 Button Replacement, Reset and Wi-Fi Buttons: adım 1, 1 resimden 1.
    • Place the router on one side so that the rubber stands are facing upward.
    • Remove the stands from the left corners only, relative to the AT&T logo if facing upright.
  2. AT&T NVG510 Button Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Satın Al
  3. AT&T NVG510 Button Replacement: adım 3, 2 resimden 1. AT&T NVG510 Button Replacement: adım 3, 2 resimden 2.
    • Pry open the case to reveal the board.
    • Some force may be required.
    • Take out the one screw located on the center-right area of the board.
  4. AT&T NVG510 Button Replacement: adım 4, 2 resimden 1. AT&T NVG510 Button Replacement: adım 4, 2 resimden 2.
    • Lift the board slowly out of the case.
    • Be careful as to not damage the board.
  5. AT&T NVG510 Button Replacement: adım 5, 1 resimden 1.
    • Locate the buttons to the right of the yellow ports along the edge of the board.
  6. AT&T NVG510 Button Replacement: adım 6, 3 resimden 1. AT&T NVG510 Button Replacement: adım 6, 3 resimden 2. AT&T NVG510 Button Replacement: adım 6, 3 resimden 3.
    • Locate the silver points that connect the buttons to the board.
    • To release the buttons, use a soldering iron to heat up and melt the silver connecting points.
    • Avoid touching the solder to the board. Touch only the silver points.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 562
