Giriş
This guide will show you how to locate, remove, and replace the buttons on the AT&T NVG510 modem. In the event that a button becomes stuck or your router becomes unresponsive when you press a button, you may need to replace it. This guide does require you to be able to operate a soldering iron carefully.
Neye ihtiyacın var
Place the router on one side so that the rubber stands are facing upward.
Remove the stands from the left corners only, relative to the AT&T logo if facing upright.
Bu adımda kullanılan alet:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Remove two screws using a 2.0 flathead screwdriver.
3 farklı kişi bu kılavuzu tamamladı.
