Giriş
The speaker inside the handset is what allows the user to hear what is coming through the phone line. If no noise is coming through the handset, replacing the speaker might be required to remedy the issue.
In order to complete this guide you will need to solder/desolder. If you are not familiar with this process, read about it in our Soldering guide.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Separate the two sections of the handset by pushing them apart with the tip of the metal spudger or opening tool.
Bir başkası bu kılavuzu tamamladı.
