Ana içeriğe geç
ATT CL2940 Speakerphone Replacement
Neye ihtiyacın var
  1. ATT CL2940 Speakerphone Replacement, Back Panel: adım 1, 3 resimden 1. ATT CL2940 Speakerphone Replacement, Back Panel: adım 1, 3 resimden 2. ATT CL2940 Speakerphone Replacement, Back Panel: adım 1, 3 resimden 3.
    • Remove five 9.5 mm Phillips #1 screws from the back panel of the phone.
  2. ATT CL2940 Speakerphone Replacement: adım 2, 3 resimden 1. ATT CL2940 Speakerphone Replacement: adım 2, 3 resimden 2. ATT CL2940 Speakerphone Replacement: adım 2, 3 resimden 3.
    • Slide the metal spudger into the crack and continue around to the front panel of the phone.
    • Be careful not to break the clips that hold the back panel to the front panel.
  3. ATT CL2940 Speakerphone Replacement: adım 3, 1 resimden 1.
    • When setting the back panel down, be careful to not rip any of the wires off of the internal components.
  4. ATT CL2940 Speakerphone Replacement, Speakerphone: adım 4, 2 resimden 1. ATT CL2940 Speakerphone Replacement, Speakerphone: adım 4, 2 resimden 2.
    • Remove the front panel of the device as shown.
  5. ATT CL2940 Speakerphone Replacement: adım 5, 3 resimden 1. ATT CL2940 Speakerphone Replacement: adım 5, 3 resimden 2. ATT CL2940 Speakerphone Replacement: adım 5, 3 resimden 3.
    • Desolder the speakerphone with a soldering iron.
    • If you are unfamiliar with solder, check out the article on soldering and be very careful. The iron is hot!
  6. ATT CL2940 Speakerphone Replacement: adım 6, 2 resimden 1. ATT CL2940 Speakerphone Replacement: adım 6, 2 resimden 2.
    • Use the soldering iron to reconnect the wires to the new speaker.
    • Place the new speaker back in place.
    • Make sure that all of the components are back in place.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Charles Messmore
541 İtibar
5 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-1, Harley Spring 2016 IUPUI, Team 1-1, Harley Spring 2016 üyesi
IUPUI-HARLEY-S16S1G1
4 Üyeler
13 adet Kılavuz yazıldı
Bir Yorum
Why do all these repairs require NO PARTS to replace defective parts?
And, of course< there is no links to a place to purchase the needed parts...
rpoland - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 617
