Ana içeriğe geç
AYL SoundFit Motherboard Replacement
Neye ihtiyacın var
    1. AYL SoundFit Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
      • Unscrew the four hex screws on the top of the device using a 2.5mm hex screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. AYL SoundFit Motherboard Replacement: adım 2, 1 resimden 1.
      • Place a spudger between the black plastic cover and the green case.
      • Remove the black cover away from the main casing and remove the cover.
      FixBot'a Sor
      Yorum Ekle
    3. AYL SoundFit Motherboard Replacement: adım 3, 1 resimden 1.
      • Place the spudger tool between the black housing, which contains the woofer, and the outer rubber casing.
      • Remove the housing away from the body to reveal the motherboard, speaker, and battery.
      FixBot'a Sor
      Yorum Ekle
    4. AYL SoundFit Motherboard Replacement: adım 4, 2 resimden 1. AYL SoundFit Motherboard Replacement: adım 4, 2 resimden 2.
      • Remove the two Phillips screws which hold its battery casing on the housing using a PH00 Phillips screwdriver.
      • Remove the battery case to reveal the battery.
      FixBot'a Sor
      Yorum Ekle
    5. AYL SoundFit Motherboard Replacement: adım 5, 1 resimden 1.
      • Using a soldering iron, heat up and remove both the positive and negative battery contacts from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    6. AYL SoundFit Motherboard Replacement: adım 6, 3 resimden 1. AYL SoundFit Motherboard Replacement: adım 6, 3 resimden 2. AYL SoundFit Motherboard Replacement: adım 6, 3 resimden 3.
      • Remove all three Phillips screws which holds the motherboard to the base using a PH00 Phillips screwdriver.
      • The motherboard can now be wiggled free from the base.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
john
171 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 3-3, Harley Spring 2016 IUPUI, Team 3-3, Harley Spring 2016 üyesi
IUPUI-HARLEY-S16S3G3
4 Üyeler
10 adet Kılavuz yazıldı
3Kılavuz Yorumları
Where do u get a new motherboard at?
calvinsmith522 - Yanıt Paylaş
Anybody know where to get a motherboard?
David Whitman - Yanıt Paylaş
Where do I get a motherboard?
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 28
Her zaman: 2,037
