Ana içeriğe geç
AYL SoundFit Motherboard Replacement
Neye ihtiyacın var
  1. AYL SoundFit Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Unscrew the four hex screws on the top of the device using a 2.5mm hex screwdriver.
  2. AYL SoundFit Motherboard Replacement: adım 2, 1 resimden 1.
    • Place a spudger between the black plastic cover and the green case.
    • Remove the black cover away from the main casing and remove the cover.
  3. AYL SoundFit Motherboard Replacement: adım 3, 1 resimden 1.
    • Place the spudger tool between the black housing, which contains the woofer, and the outer rubber casing.
    • Remove the housing away from the body to reveal the motherboard, speaker, and battery.
  4. AYL SoundFit Motherboard Replacement: adım 4, 2 resimden 1. AYL SoundFit Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the two Phillips screws which hold its battery casing on the housing using a PH00 Phillips screwdriver.
    • Remove the battery case to reveal the battery.
  5. AYL SoundFit Motherboard Replacement: adım 5, 1 resimden 1.
    • Using a soldering iron, heat up and remove both the positive and negative battery contacts from the motherboard.
  6. AYL SoundFit Motherboard Replacement: adım 6, 3 resimden 1. AYL SoundFit Motherboard Replacement: adım 6, 3 resimden 2. AYL SoundFit Motherboard Replacement: adım 6, 3 resimden 3.
    • Remove all three Phillips screws which holds the motherboard to the base using a PH00 Phillips screwdriver.
    • The motherboard can now be wiggled free from the base.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
john
171 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 3-3, Harley Spring 2016 IUPUI, Team 3-3, Harley Spring 2016 üyesi
IUPUI-HARLEY-S16S3G3
4 Üyeler
5 adet Kılavuz yazıldı
3 Yorum
Where do u get a new motherboard at?
calvinsmith522 - Yanıt
Anybody know where to get a motherboard?
David Whitman - Yanıt
Where do I get a motherboard?
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 1,541
