Ana içeriğe geç
Accessing Logicboard
Neye ihtiyacın var
  1. Accessing Logicboard, Front and Back Cover: adım 1, 2 resimden 1. Accessing Logicboard, Front and Back Cover: adım 1, 2 resimden 2.
    • Remove the following screws:
    • Two silver 3.15mm Phillips #00 screws on the right side of the camera
    • Two silver 2.08mm Phillips #00 screws on the left side of the camera
    FixBot'a Sor
    Yorum Ekle
  2. Accessing Logicboard: adım 2, 1 resimden 1.
    • Remove the two indicated screws on the bottom of the camera:
    • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
    • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
    FixBot'a Sor
    Yorum Ekle
  3. Accessing Logicboard: adım 3, 2 resimden 1. Accessing Logicboard: adım 3, 2 resimden 2.
    • Carefully pull the back of casing away from the front.
    FixBot'a Sor
    Yorum Ekle
  4. Accessing Logicboard: adım 4, 3 resimden 1. Accessing Logicboard: adım 4, 3 resimden 2. Accessing Logicboard: adım 4, 3 resimden 3.
    • After removing the back cover, several things must be removed.
    • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
    FixBot'a Sor
    Yorum Ekle
  5. Accessing Logicboard: adım 5, 2 resimden 1. Accessing Logicboard: adım 5, 2 resimden 2.
    • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
    FixBot'a Sor
    Yorum Ekle
  6. Accessing Logicboard, Logicboard: adım 6, 2 resimden 1. Accessing Logicboard, Logicboard: adım 6, 2 resimden 2.
    • On the front of the camera, in battery case, remove screws indicated:
    • Two black 2.05mm Phillips #00 screws
    FixBot'a Sor
    Yorum Ekle
  7. Accessing Logicboard: adım 7, 2 resimden 1. Accessing Logicboard: adım 7, 2 resimden 2.
    • Flip the camera over to the backside and remove screws indicated:
    • The screw circled in red is a longer black 3.00mm Phillips #00 screw
    • The screw circled in blue is a shorter black 2.00mm Phillips #00 screw
    FixBot'a Sor
    Yorum Ekle
  8. Accessing Logicboard: adım 8, 1 resimden 1.
    • Pull the cover plate off for the two power cord jacks.
    FixBot'a Sor
    Yorum Ekle
  9. Accessing Logicboard: adım 9, 3 resimden 1. Accessing Logicboard: adım 9, 3 resimden 2. Accessing Logicboard: adım 9, 3 resimden 3.
    • Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder.
    FixBot'a Sor
    Yorum Ekle
  10. Accessing Logicboard: adım 10, 1 resimden 1.
    • Remove the orange tape on top of the SD cardholder.
    FixBot'a Sor
    Yorum Ekle
  11. Accessing Logicboard: adım 11, 1 resimden 1.
    • Open the battery cover.
    FixBot'a Sor
    Yorum Ekle
  12. Accessing Logicboard: adım 12, 2 resimden 1. Accessing Logicboard: adım 12, 2 resimden 2.
    • Lift the indicated plastic piece off.
    FixBot'a Sor
    Yorum Ekle
  13. Accessing Logicboard: adım 13, 2 resimden 1. Accessing Logicboard: adım 13, 2 resimden 2.
    • Remove screws indicated:
    • Two black 4.80mm Phillips #00 screws
    FixBot'a Sor
    Yorum Ekle
  14. Accessing Logicboard: adım 14, 1 resimden 1.
    • Unsolder points indicated.
    • Please refer to steps 1 through 6 of the Ifixit soldering guide to unsolder these leads.
    FixBot'a Sor
    Yorum Ekle
  15. Accessing Logicboard: adım 15, 3 resimden 1. Accessing Logicboard: adım 15, 3 resimden 2. Accessing Logicboard: adım 15, 3 resimden 3.
    • Carefully lift up SD cardholder to reveal logicboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Nicole Wong
371 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-29, Regan Winter 2011 Cal Poly, Team 4-29, Regan Winter 2011 üyesi
CPSU-REGAN-W11S4G29
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 36
Her zaman: 1,972
