Ana içeriğe geç
Acer Aspire 5 A515-46-R3UB RAM Replacement
Neye ihtiyacın var
    1. Acer Aspire 5 A515-46-R3UB RAM Replacement, Battery: adım 1, 2 resimden 1. Acer Aspire 5 A515-46-R3UB RAM Replacement, Battery: adım 1, 2 resimden 2.
      • Use a JIS #1 screwdriver to remove eleven 6.7 mm screws from the bottom cover.
      FixBot'a Sor
      Yorum Ekle
    2. Acer Aspire 5 A515-46-R3UB RAM Replacement: adım 2, 2 resimden 1. Acer Aspire 5 A515-46-R3UB RAM Replacement: adım 2, 2 resimden 2.
      • Use an opening tool and picks to pry the bottom cover from the laptop.
      • Work your way around the perimeter of the bottom cover, releasing any clips before you remove the bottom case.
      • Remove the bottom case.
      FixBot'a Sor
      Yorum Ekle
    3. Acer Aspire 5 A515-46-R3UB RAM Replacement: adım 3, 2 resimden 1. Acer Aspire 5 A515-46-R3UB RAM Replacement: adım 3, 2 resimden 2.
      • Remove the two pieces of tape from the battery and the battery connector.
      • Save the tape for reassembly.
      FixBot'a Sor
      Yorum Ekle
    4. Acer Aspire 5 A515-46-R3UB RAM Replacement: adım 4, 2 resimden 1. Acer Aspire 5 A515-46-R3UB RAM Replacement: adım 4, 2 resimden 2.
      • Use the plastic opening tool to carefully push on each side of the connector and remove it from the socket.
      FixBot'a Sor
      Yorum Ekle
    5. Acer Aspire 5 A515-46-R3UB RAM Replacement: adım 5, 2 resimden 1. Acer Aspire 5 A515-46-R3UB RAM Replacement: adım 5, 2 resimden 2.
      • Lift up the battery and remove it from the bottom case of the laptop.
      FixBot'a Sor
      Yorum Ekle
    1. Acer Aspire 5 A515-46-R3UB RAM Replacement, RAM: adım 6, 2 resimden 1. Acer Aspire 5 A515-46-R3UB RAM Replacement, RAM: adım 6, 2 resimden 2.
      • After opening the computer case, remove the RAM device from its slot as indicated in the photos.
      • Insert upgraded RAM into this slot.
      • Repeat the steps in reverse order to reassemble the computer.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 55
Her zaman: 937
