Ana içeriğe geç
Acer Aspire 5 A515-46-R3UB SSD Replacement
Neye ihtiyacın var
  1. Acer Aspire 5 A515-46-R3UB SSD Replacement, Battery: adım 1, 2 resimden 1. Acer Aspire 5 A515-46-R3UB SSD Replacement, Battery: adım 1, 2 resimden 2.
    • Use a JIS #1 screwdriver to remove eleven 6.7 mm screws from the bottom cover.
  2. Acer Aspire 5 A515-46-R3UB SSD Replacement: adım 2, 2 resimden 1. Acer Aspire 5 A515-46-R3UB SSD Replacement: adım 2, 2 resimden 2.
    • Use an opening tool and picks to pry the bottom cover from the laptop.
    • Work your way around the perimeter to release any clips before you remove the bottom case.
    • Remove the bottom case.
  3. Acer Aspire 5 A515-46-R3UB SSD Replacement: adım 3, 2 resimden 1. Acer Aspire 5 A515-46-R3UB SSD Replacement: adım 3, 2 resimden 2.
    • Remove the two pieces of tape from the battery and the battery connector.
    • Save the tape for reassembly.
  4. Acer Aspire 5 A515-46-R3UB SSD Replacement: adım 4, 2 resimden 1. Acer Aspire 5 A515-46-R3UB SSD Replacement: adım 4, 2 resimden 2.
    • Use the plastic opening tool to carefully push on each side of the connector and remove it from the socket.
  5. Acer Aspire 5 A515-46-R3UB SSD Replacement: adım 5, 2 resimden 1. Acer Aspire 5 A515-46-R3UB SSD Replacement: adım 5, 2 resimden 2.
    • Lift up the battery and remove it from the bottom case of the laptop.
  6. Acer Aspire 5 A515-46-R3UB SSD Replacement, SSD: adım 6, 1 resimden 1.
    • Use a JIS #1 screwdriver to remove the single 3.2 mm mounting screw from the SSD.
    • When you remove the screw, the SSD card will pop up slightly.
  7. Acer Aspire 5 A515-46-R3UB SSD Replacement: adım 7, 2 resimden 1. Acer Aspire 5 A515-46-R3UB SSD Replacement: adım 7, 2 resimden 2.
    • Gently slide the SSD from the socket.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 8
Son 30 gün: 22
Her zaman: 258
