Ana içeriğe geç
Acer Aspire 5 A515-46-R3UB Speakers Replacement
Neye ihtiyacın var
  1. Acer Aspire 5 A515-46-R3UB Speakers Replacement, Battery: adım 1, 2 resimden 1. Acer Aspire 5 A515-46-R3UB Speakers Replacement, Battery: adım 1, 2 resimden 2.
    • Use a JIS #1 screwdriver to remove eleven 6.7 mm screws from the bottom cover.
  2. Acer Aspire 5 A515-46-R3UB Speakers Replacement: adım 2, 2 resimden 1. Acer Aspire 5 A515-46-R3UB Speakers Replacement: adım 2, 2 resimden 2.
    • Use an opening tool and picks to pry the bottom cover from the laptop.
    • Work your way around the perimeter to release any clips before you remove the bottom case.
    • Remove the bottom case.
  3. Acer Aspire 5 A515-46-R3UB Speakers Replacement: adım 3, 2 resimden 1. Acer Aspire 5 A515-46-R3UB Speakers Replacement: adım 3, 2 resimden 2.
    • Remove the two pieces of tape from the battery and the battery connector.
    • Save the tape for reassembly.
  4. Acer Aspire 5 A515-46-R3UB Speakers Replacement: adım 4, 2 resimden 1. Acer Aspire 5 A515-46-R3UB Speakers Replacement: adım 4, 2 resimden 2.
    • Use the plastic opening tool to carefully push on each side of the connector and remove it from the socket.
  5. Acer Aspire 5 A515-46-R3UB Speakers Replacement: adım 5, 2 resimden 1. Acer Aspire 5 A515-46-R3UB Speakers Replacement: adım 5, 2 resimden 2.
    • Lift up the battery and remove it from the bottom case of the laptop.
  6. Acer Aspire 5 A515-46-R3UB Speakers Replacement, Speakers: adım 6, 3 resimden 1. Acer Aspire 5 A515-46-R3UB Speakers Replacement, Speakers: adım 6, 3 resimden 2. Acer Aspire 5 A515-46-R3UB Speakers Replacement, Speakers: adım 6, 3 resimden 3.
    • Lift the speakers off of the mounting pegs.
    • There is a speaker in the bottom left corner and bottom right corner.
  7. Acer Aspire 5 A515-46-R3UB Speakers Replacement: adım 7, 2 resimden 1. Acer Aspire 5 A515-46-R3UB Speakers Replacement: adım 7, 2 resimden 2.
    • Undo the cables connecting both speakers from their routing hooks.
  8. Acer Aspire 5 A515-46-R3UB Speakers Replacement: adım 8, 3 resimden 1. Acer Aspire 5 A515-46-R3UB Speakers Replacement: adım 8, 3 resimden 2. Acer Aspire 5 A515-46-R3UB Speakers Replacement: adım 8, 3 resimden 3.
    • Pull the speaker cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • To remove the cable from its mounting position, use a spudger to lift the ribbon cables off of the speaker cord.
    • Now that the speaker cable is released, remove the speakers.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 266
