Ana içeriğe geç
Acer Aspire 5100 Keyboard Replacement
Neye ihtiyacın var
  1. Acer Aspire 5100 Keyboard Replacement, Keyboard: adım 1, 2 resimden 1. Acer Aspire 5100 Keyboard Replacement, Keyboard: adım 1, 2 resimden 2.
    • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
    • Use an opening tool to remove the panel above the keyboard that has the power button on it.
    • After you have released the tabs, lift up the panel.
  2. Acer Aspire 5100 Keyboard Replacement: adım 2, 3 resimden 1. Acer Aspire 5100 Keyboard Replacement: adım 2, 3 resimden 2. Acer Aspire 5100 Keyboard Replacement: adım 2, 3 resimden 3.
    • Under the panel, remove the two screws that connect the keyboard to the laptop.
    • One screw is located above the F5 button, and the other one is located above the F10 button.
    • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  3. Acer Aspire 5100 Keyboard Replacement: adım 3, 1 resimden 1.
    • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
    • Pull the ribbon under the keyboard to detach it from the motherboard.
    • Remove the keyboard.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Brad Rollinson
1.113 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-39, Forte Fall 2010 Cal Poly, Team 14-39, Forte Fall 2010 üyesi
CPSU-FORTE-F10S14G39
5 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
this step is missing steo 0 : before you lift the panel, remove 3 screw that hold the panel
Rifqi Khairur Rahman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 24
Her zaman: 13,374
