Ana içeriğe geç
Acer Aspire 5253 Hard Drive Replacement
Cynthia Barajas
Cynthia Barajas ve 4 diğer katkıda bulunanlar
En son November 30, 2023 tarihinde güncellendi
2 - 5 dakika
Orta
After you remove the back cover panel its not too difficult to slide the ram out of the laptop.
Neye ihtiyacın var
Aletler
  1. Acer Aspire 5253 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop over.
  2. Acer Aspire 5253 Hard Drive Replacement: adım 2, 1 resimden 1.
    • "Unlock" your battery by moving the switch as shown so that an unlocked lock on a red background is shown.
  3. Acer Aspire 5253 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Next move the other switch, while the unlocked symbol is still showing. The battery should pop up, and no longer be flush with the bottom of the laptop.
  4. Acer Aspire 5253 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Now remove the battery by lifting it out of the laptop by the side closest to the switches.
  5. Acer Aspire 5253 Hard Drive Replacement: adım 5, 1 resimden 1.
    • You have successfully removed the battery. Congratulations!
  6. Acer Aspire 5253 Hard Drive Replacement, Back Cover Panel: adım 6, 1 resimden 1.
    • Now, locate the two screws that hold the back cover panel onto the laptop.
  7. Acer Aspire 5253 Hard Drive Replacement: adım 7, 1 resimden 1.
    • Unscrew both of the screws that are holding the back panel in place with the Philips #00 head.
    • The screws are 3/8" in length and have a 1/4" head.
  8. Acer Aspire 5253 Hard Drive Replacement: adım 8, 2 resimden 1. Acer Aspire 5253 Hard Drive Replacement: adım 8, 2 resimden 2.
    • Once both screws have been removed use a plastic opening tool to lift the panel up. Starting with the indented notch , and moving left and right from there.
  9. Acer Aspire 5253 Hard Drive Replacement: adım 9, 1 resimden 1.
    • After the panel has been loosened by the plastic opening tool, take your finger, place it in the gap, and remove the panel from the laptop.
  10. Acer Aspire 5253 Hard Drive Replacement, Hard Drive: adım 10, 1 resimden 1.
    • Once the cover panel is off, locate the hard drive.
  11. Acer Aspire 5253 Hard Drive Replacement: adım 11, 2 resimden 1. Acer Aspire 5253 Hard Drive Replacement: adım 11, 2 resimden 2.
    • Locate the two screws that are holding the hard drive in place.
  12. Acer Aspire 5253 Hard Drive Replacement: adım 12, 1 resimden 1.
    • Remove the two screws using a Phillips #00 screw driver.
  13. Acer Aspire 5253 Hard Drive Replacement: adım 13, 1 resimden 1.
    • Carefully slide the hard drive in the opposite direction of where the screws are located until it dislocates.
  14. Acer Aspire 5253 Hard Drive Replacement: adım 14, 1 resimden 1.
    • Pull the hard drive out of its compartment.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Cynthia Barajas
2.258 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-11, Regan Spring 2014 Cal Poly, Team 8-11, Regan Spring 2014 üyesi
CPSU-REGAN-S14S8G11
4 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 7,598
