Ana içeriğe geç
Acer Aspire 5742 RAM Replacement
Skylar MacDonald
Skylar MacDonald ve başka bir katkıda bulunan
En son October 5, 2023 tarihinde güncellendi
5 - 10 dakika
Kolay
Topluluk-Katkılı Kılavuz
Upgrade your RAM for a noticeable increase in speed.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Acer Aspire 5742 RAM Replacement, Battery: adım 1, 3 resimden 1. Acer Aspire 5742 RAM Replacement, Battery: adım 1, 3 resimden 2. Acer Aspire 5742 RAM Replacement, Battery: adım 1, 3 resimden 3.
    • Move the battery catch to the "unlocked" position.
    • Pull back the second spring-loaded battery catch until the battery pops up.
    • Remove the battery.
  2. Acer Aspire 5742 RAM Replacement, Cover Panel: adım 2, 3 resimden 1. Acer Aspire 5742 RAM Replacement, Cover Panel: adım 2, 3 resimden 2. Acer Aspire 5742 RAM Replacement, Cover Panel: adım 2, 3 resimden 3.
    • Turn the notebook around to face you.
    • There are two Phillips #00 screws securing the cover panel to the rest of the notebook. Remove these screws.
  3. Acer Aspire 5742 RAM Replacement: adım 3, 3 resimden 1. Acer Aspire 5742 RAM Replacement: adım 3, 3 resimden 2. Acer Aspire 5742 RAM Replacement: adım 3, 3 resimden 3.
    • Use a spudger to release the panel from the plastic retaining clips keeping it in place.
    • Do not apply too much force, or you may break the clips.
    • Remove the panel and set it aside.
  4. Acer Aspire 5742 RAM Replacement, RAM: adım 4, 3 resimden 1. Acer Aspire 5742 RAM Replacement, RAM: adım 4, 3 resimden 2. Acer Aspire 5742 RAM Replacement, RAM: adım 4, 3 resimden 3.
    • The RAM is protected by a transparent cellophane cover.
    • Lift this cover away from the RAM. It will not come free from the RAM.
    • You may wish to use some Scotch tape to hold the cover in place while you work.
  5. Acer Aspire 5742 RAM Replacement: adım 5, 2 resimden 1. Acer Aspire 5742 RAM Replacement: adım 5, 2 resimden 2.
    • Pull back the retaining clips either side of the RAM.
    • It will spring up, ready to be removed.
  6. Acer Aspire 5742 RAM Replacement: adım 6, 3 resimden 1. Acer Aspire 5742 RAM Replacement: adım 6, 3 resimden 2. Acer Aspire 5742 RAM Replacement: adım 6, 3 resimden 3.
    • Hold on to opposite edges of the RAM chip and gently pull it diagonally upwards to remove it from the computer.
    • Repeat steps 5 and 6 for the second RAM chip if necessary.
  7. Acer Aspire 5742 RAM Replacement: adım 7, 2 resimden 1. Acer Aspire 5742 RAM Replacement: adım 7, 2 resimden 2.
    • When reinserting RAM, push it diagonally downwards until almost all of the gold connector strip is inside the socket.
    • Push gently down on the RAM until the retaining clips click back over it.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Skylar MacDonald
1.991 İtibar
5 adet Kılavuz yazıldı
2Kılavuz Yorumları
note to add: it only supports 8gb (2x4gb) max
SquinteyedSniper - Yanıt
Hi, not sure if this is the right place to post this troubleshooting request.
I’ve re-seated the original 4GB memory and added a further 4GB into the additional slot on my acer Aspire 5742 laptop. When I turn it on, the machine shows the initial ACER splash screen with the ‘Press <F2> to enter Setup.’ message in the bottom left-hand corner and the hard drive briefly whirls before the laptop powers down. It then powers back up and continually loops this cycle until I remove the power sources (mains and battery). When I press <F2>, I get 4 (four) short, quick beeps - which I think is telling me to re-seat the RAM. I have re-seated the RAM a handful of times without any progress in the reboot.
Any pointers please as to where I am going wrong or what to try next?
Stuart Adams - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 33
Her zaman: 10,912
